Author Topic: Checking on the latest version for SSCV4 and Zeus 8 and Zeus 16  (Read 3152 times)
Offline drlucas
Re: Checking on the latest version for SSCV4 and Zeus 8 and Zeus 16
« Reply #15 on: November 08, 2014, 07:40:30 PM »
Oh and this is what these things look like. Hope they will be nice at night.
[attachment deleted by admin]
Ryan
Offline drlucas
« Reply #16 on: November 09, 2014, 03:14:53 PM »
OK - Not working.
I am able to get test mode on the first 9 pics that I have connected, but when I go to program it's not working.
I am using port 2, 3rd pair off the FPD.
Using ID 0 for the hex file.
Firmware file: FalconZeus v0.0.0_id_0.hex.
  • Kudos: 63
« Reply #17 on: November 09, 2014, 03:16:39 PM »
Please post screen shots of FPD screen and SSC/uSC control panel.
Offline drlucas
« Reply #18 on: November 09, 2014, 04:08:27 PM »
SSC control panel?? maybe that's what I'm missing as I'm just using the Controller software. see attached though.
Offline drlucas
« Reply #19 on: November 09, 2014, 04:32:12 PM »
I may have a work around....I used Universe 1 on the FPD instead of Universe 7....i'm now going to move the wire back over and see if that did the trick... looks promising though
Offline drlucas
« Reply #20 on: November 09, 2014, 05:01:13 PM »
OK... so something is just messed up with that one pair on that one port for some reason. Once I connected up port 3 and used the first pair it worked. I'm happy my 7 mini trees are working with the Zeus 16. YEAH!!!!
Offline onesmoothhead
« Reply #21 on: November 12, 2014, 10:25:29 AM »
Hello all, I had some issues with two Zeus 8 running a large (1680) node Vertical matrix.  The original firmware I was using was causing some flashing. I re-flashed both with Zeus/Falcon firmware and was able to use the programmer created by David.  All is working fine. I had universe jumpers set to the correct universe. I used .hex 0 for universe one for firmware and .hex 1 for universe 2.  I was able to program universe ones first PIC and then set the channel to 1217 and used the Clone box to program the other 7 section or PICS to complete the channel programming for Universe 1. I then created my model for Universe 2 and set the start channel to 4097 and cloned the next 7 in universe two. I used a Zeus 8 in each universe.  I must say this is great firmware David and thank you. Here is a FB link to a video of the results shot during the day. The video does not do justice.  This Matrix is so clean in the video it is a pix-elated. Not sure why. You may notice there is no stutter or delayed light movement. https://www.facebook.com/video.php?v=422892487864760
I have a video of it at night I can post this evening when I return home if you want to see how bright and clean the firmware makes the sign run. Kevin
Offline drlucas
« Reply #22 on: November 12, 2014, 07:11:56 PM »
Nice matrix!!! Mine is running off two F16s ....the Zeus was going to be used for that, but I ended up having much better power supplies to use (spare HP DL380 power supplies) so went with the Falcon. I am very happy though with that firmware David put ..now that I have resolved my other configuration issue on the software front I had with a mix of square nodes and pixels on the same string everything is working nicely for me!!!
