Author Topic: New releases of software coming.  (Read 1408 times)
  • Kudos: 69
« on: August 31, 2014, 03:39:02 AM »
There will be some new releases to the software coming in next week or two. I want to release them when each stage is done to let you guys have them ASAP for testing.
Releases to come.
1) Support for FPDv1 and new Falcon16v1.02 firmware.
2) Support for Falcon8 with DMX output programming.
3) Support for Pixelnet to DMX bridge programming of universes. Also support for Falcon Hub with DMX output option.
Offline RichM
Re: New releases of software coming.
« Reply #1 on: September 01, 2014, 06:13:14 PM »
Thanks for the update.
I have a Falcon 8 I would like to fire up.  It's not working at the moment and I think it's the firmware.
Offline MyKroFt
  • Kudos: 55
« Reply #2 on: September 02, 2014, 05:08:53 PM »
You select a F8 and its asks about rs-485 output stuff, where you select F16V1 and it does not
Tony
Offline RichM
« Reply #3 on: September 02, 2014, 05:36:16 PM »
Tony,
The F16v1 does not have a DMX port, just a Pixelnet In and Pixelnet Out.  The F8 has a third port(RS-485) that can be configured to output DMX.  Pixelnet In, Pixelnet Out, and DMX Out.
I circled the port on the attached pdf.
[attachment deleted by admin]
« Last Edit: September 02, 2014, 05:47:59 PM by RichM »
Offline MyKroFt
  • Kudos: 55
« Reply #4 on: September 02, 2014, 07:55:02 PM »
That's right I forgot
Dumb me
