Small modification to Falcon Hub needed for DMX output port 2
Author Topic: Small modification to Falcon Hub needed for DMX output port 2  (Read 978 times)
  • Kudos: 69
« on: September 06, 2014, 07:13:19 AM »
Small modification to Falcon Hub needed for DMX output port 2. I found this error in the PCB during testing.
This error effects DMX output 2. If outputting Renard this error will not be a problem.
Modification steps.
1) Cut the trace from RN1 (resistor network) pin 5 (counting from bottom) to pin 4 of U9 (485 chip).
2) On back of PCB solder small wire to connect pin 6 (counting from bottom) of RN1 to pin 4 of U9.
All boards purchased from store will have modification done before shipping.
[attachment deleted by admin]
« Last Edit: September 06, 2014, 07:50:37 AM by David Pitts »
  • Kudos: 89
Re: Small modification to Falcon Hub needed for DMX output port 2
« Reply #1 on: September 06, 2014, 10:46:48 AM »
modification made, but not yet tested.
Offline RichM
« Reply #2 on: September 08, 2014, 06:27:55 PM »
Modification made.  I have not had the chance to test this one yet.
  • Kudos: 89
« Reply #3 on: September 08, 2014, 07:08:23 PM »
I have tested and Port #2 is working well.  That said, I made the modification before ever checking that it didn't work.
