Author Topic: "Boot Stopped. Flash Media Missing."?  (Read 791 times)
Offline Torqumada286
« on: October 14, 2014, 06:13:12 PM »
I was setting up the Pi tonight, following the excellent video series, when my Pi gave me the "Boot Stopped.  Flash Media missing.  Please reinsert" error message.  I am using a 16gb SD card.  I formatted it using the steps outlined in the video series.  Also at the same time the Pi tells me what IP addresses it has found.  What is going on?
Torqumada
Re: "Boot Stopped. Flash Media Missing."?
« Reply #1 on: October 14, 2014, 06:16:21 PM »
Plug in a USB drive.  We use a USB flash drive to store sequences, playlists, logs, etc. anything except the OS itself which. Is on the SD card.
Offline Materdaddy
  • Kudos: 10
    • Christmas On Quiet Hills
« Reply #2 on: October 14, 2014, 06:16:47 PM »
You also need a USB stick.  That's something in addition to the SD card that we require.  Your settings, sequences, etc. are stored on a USB stick that must also be inserted into your Pi.
EDIT: I'm too slow!
Offline MyKroFt
  • Kudos: 57
« Reply #3 on: October 14, 2014, 06:22:23 PM »
Going to change it to USB Media missing - its kinda misleading
Tony
  • Kudos: 69
« Reply #4 on: October 14, 2014, 06:24:03 PM »
Alan mentions the need for USB stick in the video at 3 minutes and 20 seconds of video 1. Could not resist sorry.  :)
« Reply #5 on: October 14, 2014, 06:28:35 PM »
Since I was adding any sequences to the player yet, I didn't think it was necessary.  Yes, it is a bit misleading.  Will fix that now.
Torqumada
  • Kudos: 69
« Reply #6 on: October 14, 2014, 06:46:04 PM »
Torqumada
I was just kidding. We are here to help you in any way we can. And we are glad you are giving fpp a try.
« Reply #7 on: October 14, 2014, 07:54:29 PM »
All fixed.
Torqumada
