Author Topic: Wiki entry: Falcon controllers and validated lights  (Read 2014 times)
Offline Steve Gase
« on: October 14, 2014, 10:38:18 PM »
I've added a table to the wiki showing a list of lights I've tested against the Falcon controllers (including the uSC).
http://falconchristmas.com/wiki/index.php/Main_Page#Supported_Lights_.28validated_by_members....29
The goal is to show known behavior so that purchase decisions can be made with more confidence.
The table is not yet filled out for each controller, and I'm hoping others can add their success/failures in each box over time.  Also, please add your own list of lights if not otherwise found in the table.
NOTE: The table indicates success in basic tests...  it does not necessarily indicate a thorough burn-in test (or a full season of use) has been achieved.  If you discover problems in your testing -- please report the data in this table.
  • Kudos: 71
Re: Wiki entry: Falcon controllers and validated lights
« Reply #1 on: October 15, 2014, 01:01:57 AM »
I just saw this post. Great work Steve. Thanks for your help. I am not the best at documentation so your help is very much appreciated.
David
Offline twooly
« Reply #2 on: October 15, 2014, 09:36:46 AM »
Nice I've got different flavors running off of ssc v1-v4 so Illl add those.
  • Kudos: 50
« Reply #3 on: October 16, 2014, 05:36:50 PM »
I went into edit mode and fear I will screw it all up if I try to do an update but I will vouch for WS2811 12v ip68 flexstrips from Ray.  I've used them with the F16, the SSC3 and the micro sc.
Product ID: 568458133
http://www.aliexpress.com/store/product/5m-led-digital-strip-DC12V-input-WS2811IC-256-scale-10pcs-IC-and-30pcs-5050-SMD-RGB/701799_568458133.html
Offline Steve Gase
Offline ricopico
« Reply #5 on: December 16, 2014, 02:36:42 PM »
I'm thinking of getting these for next year, and don't know if anyone's had any luck/validated these.
http://www.aliexpress.com/item/5m-lot-ws2811-150-ICs-5050-digital-RGB-Strip-150LED-IP67-tube-waterproof-dream-magic-color/1929265337.html
Basically a 150 Pixel strip running WS2811.  I think it should work.  thanks.
Offline Steve Gase
« Reply #6 on: December 16, 2014, 04:35:43 PM »
I tried similar ones that worked well.  Ws2811 5v 60/1M.
Report back your results!
