Author Topic: Channel Programming Questions.  (Read 1416 times)
Offline rdebolt
    • Christmas in Boise
« on: November 17, 2014, 09:00:35 PM »
I have 2 basic questions. 1 Do the universe jumpers on the hub still need to be on universe 1, or can you program with any universe setting now? 2 Do you still program your SSC to 1-4096 and set universe jumpers on the hub, or do you just program for the channels that you want? ie program an SSC for channel equal to software channel.
Thanks,
Roger
Offline MyKroFt
  • Kudos: 57
Re: Channel Programming Questions.
« Reply #1 on: November 17, 2014, 09:39:23 PM »
Hub is still restricted to 4096 max.  Unv 1 for programming am not sure, David will have to chime in
  • Kudos: 71
« Reply #2 on: November 17, 2014, 11:17:53 PM »
In the uSC.SSc software I think it will convert the absolute channel to 1-4096 range before sending, so enter the absolute address you want in the 1-16384 range. Trough the FPD I do not think the hub needs to be on universe one. In fact, I think it needs to be on the correct universe for SSC's to receive programming packet.
Offline rdebolt
« Reply #3 on: November 18, 2014, 08:36:00 AM »
OK I will do some more testing tonight. So what I am wondering now is, let's say I have a uSC programmed for channel 782 and want to change it to 8974 will the universe jumpers on the hub have to be @ 1 first? My assumption is yes, but I will have to test and see.
Thanks,
Roger
