Smoked 3 P10 boards
Author Topic: Smoked 3 P10 boards  (Read 15738 times)
Offline drlucas
Re: Smoked 3 P10 boards
« Reply #60 on: May 25, 2015, 07:08:11 PM »
https://vimeo.com/128831842
Ryan
Offline drlucas
« Reply #61 on: May 25, 2015, 07:08:36 PM »
.....ok replaced the bad cable and am looking good with simple test!!
Offline drlucas
« Reply #62 on: May 25, 2015, 07:10:49 PM »
https://vimeo.com/128832098
Offline JerryPlak
« Reply #63 on: May 25, 2015, 07:11:50 PM »
:-D
Jerry Plak
Offline drlucas
« Reply #64 on: May 25, 2015, 07:25:33 PM »
Ok. Something isn't quite right with the setup.   I have o4, o3 and O2 in use and 8 panels per port.
I'll test over hard wire vs wireless. But something is off.
  • Kudos: 89
« Reply #65 on: May 25, 2015, 07:37:16 PM »
Any particular reason to skip Output #1 ?
And could you confirm, using the camera angle as a reference, where is O2 connecting?
on my 3x3 panel, I did use O1 and I started on Top Left per the camera view.
« Last Edit: May 25, 2015, 08:05:18 PM by JonB256 »
Offline drlucas
« Reply #66 on: May 25, 2015, 07:37:19 PM »
https://vimeo.com/128832823
Offline drlucas
« Reply #67 on: May 26, 2015, 04:51:46 AM »
Quote
Here is a picture of one of my BBBs and Octoscroller. O1=JP1 on the board, O2 = JP2 on the board, etc. I used jp2,3,4 as o2,3,4 because when all my headers were soldered on the other board, and I was upside down looking over my panel I just plugged in my panels to the closest spot so my top 2 rows went to jp4, my middle 2 rows went to jp3 and my bottom two rows of the panel went to jp2.
I'm a bit confused on the arrows and what way they are supposed to go....my top 4 panels start at the octoscroller and flow --> to the panel 1 --> panel 2 --> panel 3 --> panel 4, then my next row the panels go the other way across such that really panel --4> panel 5 --> panel 6 --> panel 7 --> panel 8 all continue on a straight line. You can maybe see that if you look close enough on one of the other pics (in reply 52 shows it pretty good).
« Last Edit: May 26, 2015, 04:59:38 AM by drlucas »
Offline gadgetsmith
  • Kudos: 14
« Reply #68 on: May 26, 2015, 06:13:10 AM »
... so my top 2 rows went to jp4, my middle 2 rows went to jp3 and my bottom two rows of the panel went to jp2.
The arrows in the setup are to indicate if the panel is pointed up or down.  Simply match arrow direction with the up or down on the panel and your good.  In your setup rows 1,3,5 are up, and 2,4,6 are down.
Based on your pictures and information above, your setup should look like this.
https://www.dropbox.com/s/4ydsbdcyh1u8uar/Screenshot%202015-05-26%2008.09.05.png?dl=0
Your Xlights horz matrix model should start in the Top Left.
Offline drlucas
« Reply #69 on: May 26, 2015, 06:48:18 AM »
thanks for the image on Dropbox. Quite helpful. Made me realize I was I thinking 8x3 for some reason instead of 6x4. My matrix is clearly 6x4 but I was getting tripped up that I couldn't have 8x3 if I'm just using three outputs. I'll give this another whirl tonight and post up some new videos if I'm successful.
Also noticed the refresh is a bit off and there is some flickering. I'll go hard wired vs wifi and see if that makes a difference as well we make sure I am not doing any debugging activity.
Much appreciated!!
Offline drlucas
« Reply #70 on: May 26, 2015, 08:47:05 PM »
https://vimeo.com/128950335
Offline drlucas
« Reply #71 on: May 26, 2015, 08:53:17 PM »
I have the configuration working now...
p4, p3, p2, p1 (up)
p5, p6, p7, p8 (down)
Thanks for that help/hint!!
Now from the video above, there is a lot of glitching going on. Any idea what might be causing that? Anyone else notice anything similar? Running what I think is the latest version: v0.3.0-727-g2106a2b.
When xlights is paused on the output nothing is glitching. so it's a really strange one.
I created a new topic to troubleshoot this item....figured it was wise because I don't have any smoked boards because of the forewarning of how deep to put in my mounting screws!!
Thanks to all so far on getting this matrix up and running.
http://falconchristmas.com/forum/index.php/topic,2481.0.html
« Last Edit: May 27, 2015, 04:29:37 AM by drlucas »
Offline gadgetsmith
  • Kudos: 14
« Reply #72 on: May 27, 2015, 04:40:12 AM »
Looks good, except for that noise or whatever it is.
