Author Topic: Introducing New Hardware - Amp, Micro Amp - Signal Processor / Amplifier  (Read 22085 times)
  • Kudos: 71
Re: Introducing New Hardware - Amp, Micro Amp - Signal Processor / Amplifier
« Reply #15 on: January 05, 2015, 01:01:04 PM »
Here is a link to new F16v2. The signals are from left to right GND, CLK, Data, V.  This matches the same pin outs for E682 which is the most used controller in the hobby. The spacing is 3.5mm on center.
http://falconchristmas.com/forum/index.php/topic,1384.0.html
The more I think about it this may be another product I am thinking about. I think to get maximum distance from a controller to string a differential driver/receiver may be needed. Like many of the pixel extenders out there but with minimal cost. I envision  two channels of transceiving  and two channels of receiving on the other end.
« Last Edit: January 05, 2015, 01:08:43 PM by David Pitts »
Offline JerryPlak
« Reply #16 on: January 05, 2015, 07:19:30 PM »
Corey,
Thanks for the updates also Count me in for some  ;)
Jerry Plak
Offline corey872
  • Kudos: 16
    • Link to the sale...
« Reply #17 on: January 05, 2015, 07:38:25 PM »
Dave - that is a monster I hadn't seen yet!  Are you still in beta with that board or in production?
Corey
  • Kudos: 71
« Reply #18 on: January 05, 2015, 09:24:29 PM »
It is still in beta. I had to stop working on it for Christmas. I have had great tests so far and see no road blocks other then other projects. (FPD debugging, NEO and Xlights coding).
Offline tractormike21
« Reply #19 on: January 06, 2015, 07:41:45 AM »
I like this idea and cans see some great uses.  Corocanes as an example.  I would like to put a few of these in my display but distance between nodes has been a concern.  This would eliminate that concern.  I would be in for buying a few.  Great job.
Offline egenoup
« Reply #20 on: January 06, 2015, 07:42:43 AM »
I would be HIGHLY interested in 10-20 of these....
Charles
Offline zwiller
« Reply #21 on: January 06, 2015, 08:31:04 AM »
This is my fault for not keeping up on the uSC threads, but I had no idea the uSC did 50' to first node!  I would urge someone to get this info in plain sight.  Game changer for me.
Now that makes it interesting for best self contained 50' rig: Hub+uSC vs F16+uAMP  Right now, the edge going toward F16+uAMP for test mode and cost...
Sam
Offline twooly
« Reply #22 on: January 06, 2015, 07:24:53 PM »
Look at Corey's videos he has one where he was testing distance on the usc and was just using plain extension cord :)
Offline mangoat
« Reply #23 on: January 07, 2015, 03:29:02 AM »
Id be in for a few of these too.... probably a dozen or so just to have some on hand :)
« Last Edit: January 07, 2015, 04:57:03 AM by mangoat »
Offline dduck
« Reply #24 on: January 07, 2015, 01:56:29 PM »
I ran into a distance limitation with a Zeus and had to come up with an
alternative solution.     Count me in.
Online algerdes
  • Kudos: 10
« Reply #25 on: January 07, 2015, 02:06:33 PM »
Depending on cost, I'm interested in 15-25.  Possibly more.
Offline tlh
« Reply #26 on: January 07, 2015, 02:13:23 PM »
Great addition that increases options, which is always good.  Count me in!
Offline zwiller
« Reply #27 on: January 07, 2015, 02:26:32 PM »
I couldn't get more than 6' from my Zeus without issues but I got 15' when testing the SSCv4?!  F16 was good to 12' and I recall David stating 25' but need to test myself.
Sorry for not posting previously, but looking for 15-20 of these.
Offline tcom_jim
« Reply #28 on: January 07, 2015, 02:33:58 PM »
I'm interested in 5 to 10 of these as well.
Also, would it be possible to use 2 of these to extend a Pixelnet signal?  I was wondering if the device could handle the link rate of Pixelnet.  If so, would differential skew between the two signals cause a problem?
Thanks,
Offline Steve Gase
« Reply #29 on: January 07, 2015, 04:52:03 PM »
Thanks,
pixelnet (and dmx, too) is transmitted with 2 lines... a + and -.
pixelnet can already do 300ft.  to get more you can use a pixelnet splitter or a hub/controller with repeater capabilities.
