Author Topic: Falcon16v2 0.1 vs v1.03  (Read 1126 times)
Offline algerdes
  • Kudos: 7
« on: August 14, 2015, 01:20:26 PM »
I have asked before and received information about the physical changes between the Beta Board and the board that is shipping.
I am wondering if you can tell me how much difference, if any, there is in the firmware?  I have just received two spanking new ones (yes - "Kid in the Candy Store Syndrome" has set in) but will be deploying all three.
Should I be watching for anything? Is there an update for the older unit to bring it in line with the newer ones?
Does it really matter?
  • Kudos: 63
Re: Falcon16v2 0.1 vs v1.03
« Reply #1 on: August 14, 2015, 01:42:28 PM »
The beta boards need to have the new bootloader loaded with Pickit 3 or ICD 3 then firmware loaded with USB upgrade process. Then firmware wise it will be the same and will use same firmware going forward.
Offline algerdes
  • Kudos: 7
« Reply #2 on: August 14, 2015, 03:01:28 PM »
Thanks David.
Do you know if there is a wiki page on how to do this?  I have the Pickit 3.
  • Kudos: 63
« Reply #3 on: August 14, 2015, 03:02:56 PM »
Call me and I can walk you through.
« Last Edit: August 14, 2015, 10:57:18 PM by David Pitts »
Offline algerdes
  • Kudos: 7
« Reply #4 on: August 14, 2015, 08:06:44 PM »
I'll take you up on that next week, if you have time.
I'm packing for a gig tomorrow, then one on Sunday.  (When it rains, it pours.)
