Author Topic: Ribbon cables for Beagle. What is pitch?  (Read 1751 times)
Offline Greg.Ca
« on: August 21, 2015, 09:58:38 AM »
As I start to assemble my new matrix, I am looking for ribbon cables from the beagle to the first P10. As I look on EBAY, I see 16 pin IDC cables and most of them feature a 'pitch'. I have NO idea as to what is meant by 'pitch'. If they all have the same cable and the same connector on the end.....What is pitch?? Here is an example. Every offering on ebay seems to have a different 'pitch'???
http://www.ebay.com/itm/2-Pcs-2mm-Pitch-2x8-Pin-16-Pin-16-Wire-IDC-Flat-Ribbon-Cable-Length-60CM-/170927914990?hash=item27cc18ffee
And another with a different 'Pitch"
http://www.ebay.com/itm/2-54mm-Pitch-16Pin-F-F-IDC-Connector-Hard-Driver-Flat-Ribbon-Cable-148cm-Length-/311375047653?hash=item487f662be5
Any online place where I can buy a lot of 10 2-3 feet long? recommendations?
  • Kudos: 86
Re: Ribbon cables for Beagle. What is pitch?
« Reply #1 on: August 21, 2015, 10:06:44 AM »
The pitch is just the spacing of the conductors in the jack.
2.54mm is the "standard" pitch for the jack used on P10 (Hub75) cables.
Since it is a 2-row jack, the ribbon cable is sometimes listed as 1.27mm pitch.
The P10 name is the Pitch of the pixels (10mm apart)
I got all these from Amazon (and just made my own)
End connectors:
http://www.amazon.com/dp/B00E57QQVG
ribbon cable
http://www.amazon.com/dp/B00JDBZWJG
(and even though the picture shows 16 conductor, they sent me 24 conductor. I just peel off the last 8 conductors (leave the Red one alone!!! That is Pin 1).
crimper (this is not necessary, but convenient)
http://www.amazon.com/dp/B007R2JEM4
« Last Edit: August 21, 2015, 10:23:00 AM by JonB256 »
Offline stanward
« Reply #2 on: January 02, 2017, 10:19:20 PM »
Any word on the strain relief for the end connectors as well?
Oh, nevermind, I looked at the photo better and see it does come with strain reliefs.  The ratings for the connectors seem to be rather poor.
  • Kudos: 86
« Reply #3 on: January 02, 2017, 10:22:19 PM »
Strain relief is not required (but I added it on mine)
Offline stanward
« Reply #4 on: January 02, 2017, 10:34:55 PM »
Would you happen to know where I can purchase the power connectors and terminals as well?
  • Kudos: 86
« Reply #5 on: January 03, 2017, 05:41:57 AM »
CFOL (CrockettFantasyofLights) has the power cables on Pre-Sale now. They also will have the power distribution boards soon, and those are very useful when putting together larger arrays of P10s
https://www.crockettfantasyoflights.com/product/pre-sale-p10-power-cables/
https://www.crockettfantasyoflights.com/product/pre-sale-harrison-power-distro-board-rev-b/
Offline Phrog30
  • Kudos: 8
« Reply #6 on: January 03, 2017, 06:14:55 AM »
Power cables should come with the panel when you purchase.
Sent from my Pixel using Tapatalk
Offline djmc2002
« Reply #7 on: August 30, 2017, 07:51:23 PM »
As I start to assemble my new matrix, I am looking for ribbon cables from the beagle to the first P10. As I look on EBAY, I see 16 pin IDC cables and most of them feature a 'pitch'. I have NO idea as to what is meant by 'pitch'. If they all have the same cable and the same connector on the end.....What is pitch?? Here is an example. Every offering on ebay seems to have a different 'pitch' ???
I know this is a old post, but where did you finally get your cables?  How did you search from them on Ebay or Amazon?
Offline AAH
  • Kudos: 15
  • Blinky blinky blinky
    • I love blinky lights
« Reply #8 on: August 31, 2017, 02:12:18 AM »
I have the connectors, cables and octoscrolla to suit if looking for them on my site.
http://www.hansonelectronics.com.au
http://www.hansonelectronics.com.au/wp-content/uploads/Catalogue.pdf Catalogue
