Author Topic: PIC32MX564F064H ? Where do I find this at ?  (Read 1292 times)
Offline chadowamsley
« on: October 24, 2015, 11:33:03 AM »
Hello,
I was looking to reflash my Hub since Im having issues, but do not see PIC32MX564F064H in the pic32 device family. Ive searched the forum and wiki and have been unable to locate. Could somebody point me in the right direction of this please.
Thank You,
  • Kudos: 51
Re: PIC32MX564F064H ? Where do I find this at ?
« Reply #1 on: October 24, 2015, 12:26:12 PM »
What pickit software are you using?
« Reply #2 on: October 24, 2015, 01:01:57 PM »
I tried pickit 3.01 and 3.10.
  • Kudos: 51
« Reply #3 on: October 24, 2015, 03:36:34 PM »
I would try MPLAB X and when it installs you will get at least two programs.  Be sure to use IPE, that is the one that is the simplest and always seems to have the latest chip definitions.
Not sure if this is correct, but I take IPE to be Integrated Programming Environment and IDE to be Integrated Develop Environment.  We are only trying to program so be sure to use IPE.
  • Kudos: 74
« Reply #4 on: October 24, 2015, 04:54:55 PM »
It is also in Pickit 3 v1.000.
  • Kudos: 74
« Reply #5 on: October 24, 2015, 04:56:44 PM »
But the microchip on the hub has nothing to do with the 16 pixel ports. It only converts Pixelnet input to DMX that is on the three DMX output connectors.
« Reply #6 on: October 24, 2015, 05:18:29 PM »
Good to know. Im just going to use my f16 board to control a small matrix. Learned this board earlier in the year and hooked up tonight and ran perfect. Ill look at the hub when i have more time and not working long hours.
