Author Topic: Who wants a Pixelnet to 5 DMX output converter board??  (Read 4820 times)
Offline MyKroFt
  • Kudos: 54
Re: Who wants a Pixelnet to 5 DMX output converter board??
« Reply #15 on: November 08, 2013, 06:33:45 PM »
ok, let someone else have it
  • Kudos: 68
« Reply #16 on: November 18, 2013, 01:25:57 AM »
These have been built. I just need to test and send them out. The default board will have DMX universes 1 through 5 mapped to output ports. If you want some other mapping for Christmas let me know. I will make a custom firmware for you and place it in the download section of the forum. If you get with me (in this thread or pm) soon I can pre-program it for you. if not the 1-5 firmware will be loaded.
  • Kudos: 68
« Reply #17 on: November 19, 2013, 01:54:44 AM »
All boards have been tested and packaged with shipping labels. They will go out in Tuesday's mail.
  • Kudos: 86
« Reply #18 on: November 19, 2013, 08:45:24 AM »
My universe being extracted ( currently from a Smart Hub) is universe number 3 so everything will be fine.
sent from my Galaxy Note
lsdave
  • Guest
« Reply #19 on: November 21, 2013, 08:02:59 PM »
Just stumbled upon your amazing site and products. I have a bunch of RGB DMX dimming modules already. So i assume this would allow me to control those if i have your Falcon Pi Player running on a Raspberry Pi?  Also any plans to have the Falcon Pi Player be Artnet compatible? Possibly using OLA?
I would be really interested in getting one if they are still available.
  • Kudos: 48
« Reply #20 on: November 22, 2013, 06:19:12 PM »
Got my package today.  May not get to test until middle of next week when I have all the elements set in the yard or at least enough to play with.  Too much stuff laying all over right now.
Kennesaw, GA
Falcon and Lynx, all 12v
Multisync with Pi and BBB
P10 and P5
Offline twooly
  • Kudos: 13
« Reply #21 on: November 23, 2013, 05:46:14 AM »
I've got mine also.  One question, there was a small heat sink I believe taped to the outside.  What does that go to?
I should get some testing done here in the next few days and then a real test in my dads show for some optional stuff.
  • Kudos: 86
« Reply #22 on: November 23, 2013, 06:07:19 AM »
There is a voltage regulator flat against the circuit board right next to the 5vdc power input.
I haven't found it to be required, but if you think it (the regulator) is getting too hot, you slide it between the regulator and the board until the two holes match. Do this with the power off!  Then secure it with either a small machine screw and nut or even a very tight Tie Wrap. You don't want it to come loose and touch anything electrical.
  • Kudos: 68
« Reply #23 on: November 23, 2013, 11:34:16 AM »
Most  likely will not need it.
Sent from my EVO using Tapatalk
Offline djohnson
« Reply #24 on: November 27, 2013, 05:06:33 PM »
David do you have any more of these ?
do you think this may resolve the issue I have running DMX out from the FPD?
Does this board also output at 20hz? or does it have faster cycle?
  • Kudos: 68
« Reply #25 on: November 27, 2013, 05:20:25 PM »
You would be in the same boat, it is 20hz. But last night I was able to work on FPD code and my first attempt is almost done. I need to test it first. Then give it over to you to test.
Offline djohnson
« Reply #26 on: November 28, 2013, 10:52:56 AM »
great news, ready when you have something!
happy thanksgiving
