Author Topic: Mounting Options for F4V2  (Read 3861 times)
Offline L1011
« on: May 16, 2016, 08:19:42 PM »
Hi all,
Apologies if this has been brought up before.  How do you plan to mount your F4's?  It seems like a CG1500 is a bit big for this.  Any thoughts on other options?
Thx!
Offline Skunberg
Re: Mounting Options for F4V2
« Reply #1 on: May 16, 2016, 08:43:43 PM »
Cg500 is a good possibility. Maybe even a ta200.
Offline markrvp
  • Kudos: 7
« Reply #2 on: May 16, 2016, 10:57:58 PM »
Hi all,
Thx!
I think the CG-1500 is appropriate if you have both a power supply and the F4 inside the box.  The extra space for air isn't a bad thing.
Offline L1011
« Reply #3 on: May 17, 2016, 08:57:02 PM »
I found a wiki link for enclosures (wish I had seen this before I posted but oh well). It doesn't appear the TA200 will house the F4V2, but it appears to be near perfect for my Rpi's!
Link to enclosures for us noobs:  http://www.doityourselfchristmas.com/wiki/index.php?title=Enclosures
Offline jfridge92
« Reply #4 on: May 20, 2016, 06:00:40 AM »
I posted this on DIYC.com, but thought I'd share it here just to give a visual for everyone.
The F4V2 will definitely fit in a CG500, but it wouldn't really give room for a PSU. This isn't a problem if you're using power injection/distribution boards. The board will mount directly to the far left holes in the CG500 if you don't plan to make a mounting plate.
And of course there's more than enough room in a CG1500 with a PSU in there as well. Also, the board mounts directly to the case of course.
Offline Broomy111
« Reply #5 on: July 19, 2016, 06:08:35 PM »
Got my two mounted up -
Offline Skunberg
« Reply #6 on: July 19, 2016, 06:12:12 PM »
A cg1000?
Offline Broomy111
« Reply #7 on: July 19, 2016, 06:16:09 PM »
A cg1000?
1500
Offline scottmcl
« Reply #8 on: August 27, 2016, 08:21:17 AM »
What mounting plate did you use in the 1500 box for the F4V2 and power supply? Does the mounting plate for the F16V2R work for the F4V2 as well?
Offline Bshaver
  • Kudos: 22
« Reply #9 on: August 28, 2016, 08:05:10 PM »
what size hole ports did you put in there? I never thought to just drill my own holes again. Also, what did you put over the existing holes that have the foam? It could be a good thing to put some mesh for venting there? Is that what you did?
Denver Colorado
Offline stallionent
« Reply #10 on: August 29, 2016, 06:07:24 PM »
I am in the process of putting my F4 into a Bud Industries box, Need to make a plate with 2-1/4 standoffs (coming in Friday 9-2)
Offline Broomy111
« Reply #11 on: September 02, 2016, 08:16:50 PM »
I used the solid Falcon mounting plate and I think the holes lined up, but I may have drilled as well.  I can't remember since I'm working on my other boxes.   Small drill bit can make any mounting plate work. Recommend the Falcon plate though.
Offline Broomy111
« Reply #12 on: September 02, 2016, 08:18:56 PM »
If I drilled, I just did a small enough one so my stand offs would not go through.  I put galvanized metal mesh over those holes, so hope to get some ventilation from there.
Offline stallionent
« Reply #13 on: September 16, 2016, 03:06:17 PM »
Almost done with my F4 in a small Bud box, Tight fit but workable.
Offline algerdes
  • Kudos: 7
« Reply #14 on: September 20, 2016, 10:08:50 PM »
I can't tell in the picture, what are the connectors you are using? (What appear to be panel mount.)
