Author Topic: F8-Distro  (Read 10305 times)
Offline markrvp
  • Kudos: 7
Re: F8-Distro
« Reply #45 on: September 16, 2016, 07:39:24 AM »
I'm not getting any voltage drop through 20' of 18 gauge wire.  I may be doing it wrong.
  • Kudos: 86
Re: F8-Distro
« Reply #46 on: September 16, 2016, 08:55:20 AM »
The amount of voltage drop over that distance depends on the amount of current (amperage) going thru the wire.
No current means no voltage drop. If the Prop is at full power (white) and you still have no voltage drop, then that power injection may not have been needed.
Voltage drop is the difference between the voltage at the source and at the injection point when the Prop is lit.
Offline bowhunter3125
Re: F8-Distro
« Reply #47 on: December 30, 2016, 11:17:48 PM »
When can we expect these top be back in stock?
Offline PeteyHall
  • Kudos: 3
Re: F8-Distro
« Reply #48 on: December 31, 2016, 04:52:05 AM »
I have 2 or 3 extra from this season never used.
Pm me if interested.
  • Kudos: 86
Re: F8-Distro
« Reply #49 on: December 31, 2016, 06:19:04 AM »
After a flood light changeout a few days ago, I used my last two DC distribution boards (Dave's and Andy's).
I'll be watching the store during the off-season. More builds planned.
Offline code
F8-Distro
« Reply #50 on: January 11, 2017, 12:03:02 PM »
Did u ever sell these? If not . I'm in the uk and interested. If so does anyone know when we can pre order these
Offline PeteyHall
  • Kudos: 3
Re: F8-Distro
« Reply #51 on: January 11, 2017, 03:42:46 PM »
No they're still out there if anyone wants to buy them.
Not sure how much it would cost to ship them to the U.K.  Pm me your info if you'd like me to get a quote.
Offline code
Re: F8-Distro
« Reply #52 on: January 11, 2017, 11:32:45 PM »
Will pm you know
Offline Dutchsanta
Re: F8-Distro
« Reply #53 on: January 15, 2017, 02:43:13 PM »
Just asked David today about re-stock because I wanted to get some back home with me to Europe in March.
Planning is early march.
I hope they will be in on time then.
Does anybody have some laying around for sale if not??
Offline code
Re: F8-Distro
« Reply #54 on: January 28, 2017, 03:15:03 PM »
How did you get on. No rush just
Offline kosmokramer
Re: F8-Distro
« Reply #55 on: February 01, 2017, 06:51:47 AM »
Two things
1) Are you saying boards will be available in March timeframe?
2) If anyone has any extras in the US before then I would be interested
Thanks!!!!!
Offline Emuney18
  • Kudos: 3
Re: F8-Distro
« Reply #56 on: February 01, 2017, 07:49:42 PM »
Did you find any?  I have 2 I'll sell you.
Offline whitebuck
Re: F8-Distro
« Reply #57 on: February 02, 2017, 06:12:20 AM »
If you use heavier gauge wire, you can go a long ways. 14ga would let you go 15 to 20 ft. 12ga would go a lot farther.
I'm using 16ga (spt1) but more injection points because it keeps the current lower per wire.
I have points where my runs are 30+ feet wit 14 gauge and 16 gauge wires.  16 gauge was the largest I could get coming out of my boards with all the wires going into the connection and no stragglers to blow fuses.  In some cases I found it more efficient to place the distribution box closer to the injection points and run 14 gauge from the power supply.
Offline Setarcos
  • Kudos: 6
Re: F8-Distro
« Reply #58 on: February 02, 2017, 07:59:20 AM »
I use 14/2 low voltage landscape wire for power injection and it is able to fit into the screw terminals on the connectors just fine. The only issue I have run into is that the stiffness of the wire can make the connectors on the F8-Distro pop out if they do not have sufficient strain relief.
Offline zwiller
  • Falcon Beta Team
  • Kudos: 12
Re: F8-Distro
« Reply #59 on: February 02, 2017, 08:34:37 AM »
Not to steal any thunder from the F8, but I was sent a Hanson Hexfuse from AUS and thing is massively overbuilt...  90A!  I am not really into power injection but if I was, I'd look at these.  http://www.hansonelectronics.com.au/product/hexfuse/
Sam
