Author Topic: 2013 COS LightsUp  (Read 2102 times)
Offline Kevin
    • Colorado Christmas
2013 COS LightsUp
« on: May 16, 2013, 06:42:17 PM »
Here are the Power Point slides from the 2013 COS LightsUp get together.
[attachment deleted by admin]
Kevin
Colorado Christmas
Offline Nightowlz1966
    • Christmas On The Creek
Re: 2013 COS LightsUp
« Reply #1 on: May 16, 2013, 07:35:00 PM »
Hey Kevin
Do you have pics of the thin wall arches with flex strips in them ?
I worked on making some last year using 1" PVC but I am in the process of ordering some 10ft - 1" Pex pipe for this year.
Brian Flanders
Sharpsburg Ga. http://christmasonthecreek.com http://www.facebook.com/ChristmasOnTheCreek I Thought I Had More Extension Cords
Offline pk
« Reply #2 on: May 17, 2013, 12:51:48 PM »
Nightowlz1966 -  I can take some pictures.  Is there anything in particular you want to see?  Each arch is a 10 foot section which was bent (using steam) to shape on a form mms and I built.  The base (feet) are PVC (one side uses 1 inch, the other 1 1/4).  The 1 1/4 side houses the SSC.  Nothing is glued.
Here are some links to videos with the arches
mms's
http://www.youtube.com/watch?v=Su2LMwbAzqE
http://www.youtube.com/watch?v=mvu6C3tGQhs  (you can see the right side PVC base)
http://www.youtube.com/watch?v=PsfT-MR1Y4s
pk's
http://www.youtube.com/watch?v=3MmRdqkuJwU
http://www.youtube.com/watch?v=_AQpnZ8oUwE
ADMINS: move if needed... seems to have gotten off-topic
« Last Edit: May 17, 2013, 01:00:13 PM by pk »
Offline davron12
« Reply #3 on: May 23, 2013, 08:30:43 AM »
That's a lot of info to take in. Kevin, are you going to present that, or did it already happen? If it hasn't happened yet and you're presenting it, might I suggest a little less wording and a lot more pictures? You're going to loose the audience. Sorry for being a critic. The one from 2012 was great.
