Author Topic: New F4V2 Differential Expansion Board  (Read 5052 times)
Offline madsci1016
Re: New F4V2 Differential Expansion Board
« Reply #15 on: November 02, 2016, 05:37:03 PM »
Any update? Would be good to get an ETA as I need it for this season or have to come up with another plan.
  • Kudos: 68
« Reply #16 on: November 02, 2016, 07:23:07 PM »
Cannot guarantee they will be done by end of this month. So you may want to go to plan 'B'. It takes three weeks to get them built and I have not ordered them yet and may not for a week or two. I have one PCB I can send you. You will have to source and populate the parts and a few are small SMD 0603 parts.
Offline madsci1016
« Reply #17 on: November 02, 2016, 07:53:59 PM »
I'm no stranger to Digikey and 0603 soldering, so yes that would be cool. I assume you can send a BOM with it?
  • Kudos: 68
« Reply #18 on: November 02, 2016, 09:49:30 PM »
Send me a PM with your address.
Offline K-State Fan
« Reply #19 on: November 19, 2016, 01:36:11 AM »
I assume these will be available for next year.
  • Kudos: 68
« Reply #20 on: November 19, 2016, 01:46:55 AM »
Yes. Maybe sooner.
Offline K-State Fan
« Reply #21 on: November 19, 2016, 01:55:01 AM »
Good.  Think this will allow me to add pixels to the house and not have to worry about power injection.
Offline algerdes
  • Kudos: 7
« Reply #22 on: December 27, 2016, 10:56:48 PM »
David,
Just checking on the status of this most intriguing board.  Any update you can pass our way?
Offline K-State Fan
« Reply #23 on: January 16, 2017, 06:51:47 AM »
I was wonder the same thing.  Trying to plan out 2017 Christmas before presales are over.
  • Kudos: 68
« Reply #24 on: January 16, 2017, 09:59:42 PM »
The board has been tested and will be part of the presale.
Offline ebrown19721972
« Reply #25 on: January 31, 2017, 05:31:59 PM »
Will this still happen? I do not see it in the store.
Offline Emuney18
« Reply #26 on: January 31, 2017, 08:01:26 PM »
It's there currently. $22
Offline battle79
« Reply #27 on: January 31, 2017, 10:46:13 PM »
David could you outline what the no. of pixels per port (main board and receivers) will be with both ports on the differential expansion used?
Can they be adjusted to have more on some and less on others?
Regards,
Rowan
  • Kudos: 68
« Reply #28 on: January 31, 2017, 10:55:22 PM »
The F4V2 at this time allows 340 on main board and 340 on expansion board. I may change this is the future but that is how it stands now.
Offline PeteyHall
« Reply #29 on: February 01, 2017, 04:22:35 PM »
David, from the pic of the f4v2 differential board, is there a 3rd serial/rj45 port on the board to support the link from the main board?  How will it connect?
I only see 2 on the pic.
