Author Topic: Brightness adjustments/color shift?  (Read 668 times)
Offline djmc2002
« on: November 20, 2016, 11:50:20 PM »
If I lower the brightness of my pixel strings at the controller level could it effect the colors displayed?  I have a San Device E682 and a F16V2 running side by side and on the F16 then tree I have it set to 50% and the 682 is not adjusted down however the color difference between the trees is vast.  All pixels are from the same supplier, and both controllers appear to have the same layout (RGB) selected.
Any ideas what might be causing the color shift between the controllers?  Tks
