Author Topic: Differential Expansion - Ports 12 - 13 - 14 -15 & 16 are not lighting  (Read 935 times)
Offline StoneLoveLights
Please help,
Ports 12 - 13 - 14 -15 & 16 on F16V2 are not lighting since I've
installed and configured my Differential Expansion and one
Receiver board.
Pictures of:
F16V2 connected to Differential Expansion
Differential Expansion connected to receiver board.
Port Configuration Page
E131 SetUp Page
  • Kudos: 68
Re: Differential Expansion - Ports 12 - 13 - 14 -15 & 16 are not lighting
« Reply #1 on: November 30, 2016, 09:07:57 PM »
If you move a working receiver to different port on expansion does it still work.
« Reply #2 on: December 01, 2016, 04:16:03 PM »
I tried both receivers that I have and I am still not getting lights
at port 12 - 16. It's the same response from all other ports on
the expansion.
Offline JerryPlak
« Reply #3 on: December 01, 2016, 05:20:45 PM »
Is the LED lighting up on the Differential Expansion board
Jerry Plak
« Reply #4 on: December 02, 2016, 03:03:54 AM »
Yes it is.
Offline tucsonlights
« Reply #5 on: December 02, 2016, 08:01:52 AM »
I don't know if this makes a difference but the start and end channels on your port config page are not contiguous.
Offline lazzle
« Reply #6 on: December 06, 2016, 11:48:15 AM »
I'm having the same issue. F16VR2>Differential expansion>Differential Receiver... I have all lights but cannot get the pixels to run a test. I have also tried to run without using the expansion but I'm still not getting any output to the pixels.  I have another receiver I will try tonight to see if maybe it's just the board.
Offline esolo
  • Kudos: -1
« Reply #7 on: December 17, 2016, 05:39:06 PM »
+1
