Author Topic: Device Type  (Read 695 times)
Offline TNF250
Device Type
« on: December 08, 2016, 06:53:21 PM »
Which device type do I use for the String Node used on the DLA Wiki, the TM1804IC?I tried the Strings and Rectangles (TM1804) but not getting the colors in correct order RGB.
Also while doing a search I found a link to the Wiki for a color chart but can't seem to locate it.
https://www.aliexpress.com/store/product/100-node-LED-pixel-string-DC12V-input-new-model-IP68-TM1804IC/701799_495658159.html
Thanks.
Zane
Springfield, TN
X-Lights - RPi3 - FPP - Falcon - DLA Lynx
Offline t.jo13
Re: Device Type
« Reply #1 on: December 08, 2016, 07:10:24 PM »
Try them all . Cant remember which one I chose a while back but i do believe The color order is BGR . I just change it in xlights now . I just create a test sequence of red, then green and blue. Test you string and set it to the color order that works correctly.
Offline TNF250
Re: Device Type
« Reply #2 on: December 09, 2016, 08:35:47 AM »
Tried each one until it output correctly, RGB. So if anyone else is using the TM1804IC nodes from Ray select the Rectangles (TM1809).
Thanks.
