Author Topic: RJ-45 pinout from differential board to receiver board.  (Read 787 times)
Offline abhijitz
  • Kudos: -1
« on: December 18, 2016, 08:24:23 AM »
I tried couple of off-the-shelf data cables i had, did not work. Need to crimp some new ones.
Wanted to confirm what is the pin-out pattern from the differential board to the receiver board.
Is it :
straight-through? 1,2,3,4,5,6,7,8 --> 1,2,3,4,5,6,7,8
roll-over? 1,2,3,4,5,6,7,8 --> 8,7,6,5,4,3,2,1
cross-over? 1,2,3,4,5,6,7,8 --> 3,6,1,4,5,2,8
Offline darylc
Re: RJ-45 pinout from differential board to receiver board.
« Reply #1 on: December 18, 2016, 07:48:26 PM »
straight through
Offline abhijitz
  • Kudos: -1
« Reply #2 on: December 18, 2016, 09:17:23 PM »
Thanks for the confirmation.
straight through
Offline ChristmasBug
« Reply #3 on: December 18, 2016, 09:58:05 PM »
Its called Cat6- B Standard.
Going for it...
 Raspberry pi - 1 Main
 2 - Raspberry PI+PICAP
 2 x F16V2-R Pixel Controller
 5000 node  bullet PiXELS
 800 C9 PiXELS for roof out line
Offline afremont
« Reply #4 on: December 19, 2016, 01:54:16 PM »
I've been using standard cat5 568B wired cables without issue.  I'm assuming that I have split pairs then?
I had one cable with a bad crimp and I got lots of random data.  I guess that is a sign of picking up noise from another pair.  Actually, the crimp was fine, the EZ connector was missing a pin.
Sent from my Moto G (4) using Tapatalk
