Author Topic: F4V3?  (Read 3439 times)
Offline K-State Fan
F4V3?
« on: December 28, 2016, 04:30:23 PM »
Is there going to be a F4V3 for 2017?
« Last Edit: December 29, 2016, 10:05:33 AM by K-State Fan »
  • Kudos: 86
Re: R4V3?
« Reply #1 on: December 28, 2016, 08:08:04 PM »
F4V3?
Offline K-State Fan
Re: R4V3?
« Reply #2 on: December 29, 2016, 05:14:02 AM »
F4V3?
Yes F4V3
Offline Jonnyb44
Re: F4V3?
« Reply #3 on: December 29, 2016, 01:17:31 PM »
Last time i spoke with David Yes there will be..   Don't Quote me but i believe it will be able to drive the 4 Port diff board
Offline kentd
Re: F4V3?
« Reply #4 on: December 31, 2016, 09:19:07 PM »
At least a F4V?
Kent Davis
Davis County UT
Offline cswelin
Re: F4V3?
« Reply #5 on: May 05, 2017, 12:19:52 PM »
David posted a picture of a v3 in the xLights Support group on Facebook.
https://www.facebook.com/groups/628061113896314/
Offline neilric99
Re: F4V3?
« Reply #6 on: May 05, 2017, 03:00:04 PM »
David mentioned a 2 port DIFF board for the F4V3
Re: F4V3?
« Reply #7 on: May 05, 2017, 10:22:25 PM »
Yes there will be an F4V3 which will support a differential expansion board that allows two remote 4-port differential receivers for a total of 12 ports ... 4 on the main board, 4 on remote receiver 1 and 4 on remote receiver 2. (4+4+4).   He is also working on an 8 port local expansion board for F4Vx but that's not finalized yet (soon hopefully)  Only one expansion board will be supported on the F4 where two expansion boards wil be supported on the F16V3
« Last Edit: May 05, 2017, 10:38:08 PM by pixelpuppy »
Offline SlammedNiss
Re: F4V3?
« Reply #8 on: May 05, 2017, 10:50:53 PM »
I don't have an answer, but I do have a question. Where are you located? Asking because of your username.
People's misconceptions on adjustable suspensions usually come from a lack of knowledge.
  • Kudos: 68
Re: F4V3?
« Reply #9 on: May 06, 2017, 02:50:28 AM »
Shipping late May
Offline Sawdust
Re: F4V3?
« Reply #10 on: May 10, 2017, 01:04:18 AM »
Shipping late May
How do I order the F4V3
Offline K-State Fan
Re: F4V3?
« Reply #11 on: May 10, 2017, 05:32:45 AM »
MHK
Offline K-State Fan
Re: F4V3?
« Reply #12 on: May 10, 2017, 05:36:18 AM »
Shipping late May
Is it going to use the same differential expansion board as the F4V2?
  • Kudos: 68
Re: F4V3?
« Reply #13 on: May 10, 2017, 06:47:53 AM »
Shipping late May
I will be switching the webpage today but if you order an F4V2 you will be getting an F4V3.
Offline Sawdust
Re: F4V3?
« Reply #14 on: May 10, 2017, 01:06:49 PM »
David, will the F4V3 have the same 680 pixels per port, or have you been able to increase.
Help me with the Differential Expansion units.  Starting with a F4V3 and a Differential Expansion, and then add (2) 4-String Differential Receiver Board netting a 4-4-4 port arrangement what would be a typical pixel assignment?   Assuming 680 is still the limit, then   340 - 170 -170 would be one option yes?  Is 680 still the limit?
What about this: (still assuming 680 pixel per port)
Port # - - - base board . . . . 1st expansion . . . . 2nd expansion
1 . . . . . . . 100. . . . . . . . . . 500 . . . . . . . . . . .100
2. . . . . . . .340. . . . . . . . . . 170 . . . . . . . . . . .170
3 . . . . . . . 0. . . . . . . . . . . . 680 . . . . . . . . . . .0
4 . . . . . . . 170. . . . . . . . . . 170 . . . . . . . . . . .340
