Author Topic: Micro SDHC card  (Read 494 times)
Offline Dldesper
Micro SDHC card
« on: January 22, 2017, 10:55:31 AM »
Has anyone had a micro card overheat and crash in there Raspberry PI.
Offline tbone321
  • Kudos: 45
Re: Micro SDHC card
« Reply #1 on: January 22, 2017, 12:31:07 PM »
That is not common.  I would take a look at the PS and make sure that it is supplying the correct voltage and if so, I would try a fresh install on a new SD card and see what happens.  It could be a defective PI.
Offline Dldesper
Re: Micro SDHC card
« Reply #2 on: January 22, 2017, 12:40:48 PM »
My PI worked all christmas with no problems, when I put the falcon PI cap on it and pluged only the USB power to the PI it wouldnt boot up and the micro card got hot.
Offline tbone321
  • Kudos: 45
Re: Micro SDHC card
« Reply #3 on: January 22, 2017, 12:59:49 PM »
It sounds like something may be wrong with the cap.
Offline rlemery
Re: Micro SDHC card
« Reply #4 on: January 22, 2017, 01:34:09 PM »
I would take a good look for solder bridges on the Pi cap. Sounds like something is shorting out.
728 lor channels
5492 pixels
  • Kudos: 69
Re: Micro SDHC card
« Reply #5 on: January 22, 2017, 01:54:33 PM »
Did you remove the jumper on Picap since you are powering pi fron usb
Sent from my LGLS992 using Tapatalk
Offline Dldesper
Re: Micro SDHC card
« Reply #6 on: January 22, 2017, 03:18:45 PM »
Oops, no I didnt, put the power usb to PI was the only wire connected to either unit. Hum
« Last Edit: January 22, 2017, 04:16:45 PM by Dldesper »
