Author Topic: Falcon Player - FPP v1.9 is now available  (Read 16046 times)
Offline rlemery
Re: Falcon Player - FPP v1.9 is now available
« Reply #15 on: May 27, 2017, 07:51:13 PM »
Can you post screen shots of your eth0 and wlan0 pages?
728 lor channels
5492 pixels
  • Kudos: 179
« Reply #16 on: May 27, 2017, 10:18:39 PM »
Well i am at a loss. I was finally able to get back into my pi, but still have no upgrade button. When i set the DNS settings to what the DNS settings were in my router, the pi froze up, had to go into the thumb drive and erase the static IP for the wlan.
On the Troubleshooting Commands page in the FPP UI, look for the section that says "Internet Access:    ping -c 1 github.com".  Copy the text in that section into a post here, or, just attach your logs zip which will also contain the troubleshooting commands output.
Offline bowhunter3125
« Reply #17 on: May 27, 2017, 11:16:23 PM »
ping: unknown host github.com
« Reply #18 on: May 27, 2017, 11:20:36 PM »
I should add that i am running v 1.8-11
  • Kudos: 48
« Reply #19 on: May 28, 2017, 12:24:42 PM »
If you are getting unknown host you are not connected to the internet.  So that would mean some kind of internet issue be it configuration or wiring or wifi connection.
I always put in the DNS area the ip of my router I am connected to and the ip of google dns which is 8.8.8.8
Kennesaw, GA
Falcon and Lynx, all 12v
Multisync with Pi and BBB
P10 and P5
« Reply #20 on: May 28, 2017, 12:57:23 PM »
I will try that.
« Reply #21 on: May 28, 2017, 01:34:30 PM »
well, set my DNS to match my modem, i can access the  pi through the wlan , but still no upgrade button.
« Reply #22 on: May 28, 2017, 01:46:11 PM »
Think i may have to hook this up directly to the modem. I shouldn't have to with it being hooked up with the wifi but i cant get anything else to work.
  • Kudos: 48
« Reply #23 on: May 28, 2017, 06:33:34 PM »
Did you notice the bottom couple of lines on iwconfig.  I cannot interpret them, but it would indicate to me that your wifi is not connecting.  I had problems with case one time with wifi.  Both the ssid and the pw are case sensitive on Linux/FPP.
« Reply #24 on: May 28, 2017, 07:28:23 PM »
The moment i brought it inside i was able to get the down load button. Did not even have to hard line to the modem. I think the Wifi module on the Pi 3 is not very strong.
  • Kudos: 48
« Reply #25 on: May 29, 2017, 07:15:33 AM »
Since I can reach all 5 of my Pi3's via wifi from anywhere in my yard or my house and even from across the street I doubt that it is the Pi3, but it may be the wifi environment where you live.
Offline Emuney18
« Reply #26 on: May 30, 2017, 05:46:40 AM »
bowhunter3125. Try looking at the signal strength using your phone  or under troubleshooting on the FPP page.  Here is a discussion about this last year.
Wi-Fi Signal Strength?
https://r.tapatalk.com/shareLink?share_fid=64886&share_tid=5909&url=http%3A%2F%2Fwww%2Efalconchristmas%2Ecom%2Fforum%2Findex%2Ephp%3Ftopic%3D5909&share_type=t
« Reply #27 on: May 30, 2017, 09:04:32 AM »
37/70. I will have to move it the front yard and out of the garage see what happens. But i will be running it off a dedicated router, one with external
[size=78%] antennas, not the pierce of junk century link modem i have now.[/size]
Offline Emuney18
« Reply #28 on: June 01, 2017, 06:23:34 AM »
[/quote]
[/quote]
 Wait until you have the final router then get a long extension cord and just go around and test. I honestly don't know what you would be wanting over 70.  Worst case is get an antenna for the Pi or use something like this and disable the onboard wifi.
Wifi With Antenna For Raspberry Pi - Instructions Included - PLUG and PLAY https://www.amazon.com/dp/B00H95C0A2/ref=cm_sw_r_cp_api_2AamzbQ6BATAM
Offline Santacarl
« Reply #29 on: July 07, 2017, 07:06:13 PM »
I'm a bit late finding this thread so my question might not get a response but I'll ask anyhow....
I'm woefully inadequate in my understanding of networks and have always used the "DHCP" setting under the Network tab instead of static....
So you have a choice between "static" or "DHCP"...  What criteria would tell me to use 1 over the other?
