Author Topic: FPP with e682s not working properly  (Read 641 times)
Offline mrgimmeone
« on: February 05, 2017, 06:17:20 PM »
i just bought a 2nd e682 and tried to add it to my show. 1st 1 runs the 16 string mega tree (50 nodes per channel). i did test it 2 weeks ago but it was still set up on other effects so it wasnt working properly but it did all light up. i have since changed it to work as my mega tree controller and was testing it set up as such. in xlights it shows in setup as my 1st controller starting at universe 1 using channels 1-8,192. now during a test only about half the string is lighting up and if i move the string to next channel the other half will light up. i just don't understand why that is. am i supposed to set each string to only have 150 channels or is 512 per string correct as i have it now. and on 2nd e682 the channels that each effect says they are on do not match up when you run the test. like (tree 1 on universe 1 is not in that output on the controller) it's showing up in a different output. is this normal or is there a certain way to set this up. in xlights i do have 3 e682s in the show even tho i dont have a 3rd yet actually hooked up to the FPP. this pic is of the new e682.
« Last Edit: February 05, 2017, 06:41:37 PM by mrgimmeone »
Offline mrgimmeone
Re: FPP with e682s not working properly
« Reply #1 on: February 05, 2017, 06:41:09 PM »
the 1st e682 setup.  i guess what i'm trying to say is do you HAVE to have say all 3 controllers hooked up or can you test 1 controller at a time while my xlight is setup as a possible 3 controller setup.
« Last Edit: February 05, 2017, 08:32:30 PM by mrgimmeone »
