Author Topic: ACtivate onboard PI 3 audio  (Read 386 times)
Offline Needbin
« on: June 08, 2017, 02:31:02 PM »
How do you activate the onboard audio port on the raspberry pi 3.. I know its not the best, but it is a starting point..
Offline jholmes
Re: ACtivate onboard PI 3 audio
« Reply #1 on: June 08, 2017, 06:30:15 PM »
Should be activated by default.
Offline Needbin
« Reply #2 on: June 08, 2017, 07:11:36 PM »
Nothing to select in the settings.
  • Kudos: 47
« Reply #3 on: June 08, 2017, 08:44:25 PM »
I have more than 6 Pi3s and I have never activated audio out, but every one of the pis that I hooked to speakers had audio.  For my show last year I used a Pi B+ only because I had read many posts that indicated it had better audio than the 3.  But I never tried to compare them.  I even have a portable P10 matrix setup that runs off a Pi matrix adapter on a Pi3. It is powered by a cell phone battery charger.  I have speakers hooked up that come off the Pi3 audio jack and use power from the cell phone charger and it works fine.
Kennesaw, GA
Falcon and Lynx, all 12v
Multisync with Pi and BBB
P10 and P5
Offline Jonnyb44
« Reply #4 on: June 09, 2017, 01:42:23 PM »
Did you have a hat setup on the pi?  If so it disables onboard audio
  • Kudos: 47
« Reply #5 on: June 09, 2017, 03:25:23 PM »
Darn, my short, or is it aged, memory forgot that I have a USB audio for the Pi3 I use with my matrix adapter.  I built that after the Expo last year.
But I do hook up a speaker to the audio jack everytime I build a new Pi image so that I can hear the Ip addr that comes over the speakers as it finishes booting up.
