Author Topic: Ribbon Cable Connection between expansion board and F16-V2 R  (Read 480 times)
Offline Chaz
I'm probably missing something obvious, but it isn't clear to me how the ribbon connector connects to the F16-V2 controller. The connector does not appear to be keyed and it seems to fit in either configuration.
Is there any documentation on the expansion board> I didn't get anything with the delivery.
Chaz
Offline rstehle
Re: Ribbon Cable Connection between expansion board and F16-V2 R
« Reply #1 on: July 12, 2017, 03:11:51 PM »
The side with the red wire goes to the left on both boards.
Offline Ebuechner
  • Kudos: 7
« Reply #2 on: July 12, 2017, 03:13:31 PM »
I'm not familiar with that board but in almost all cases with ribbon cable the pins have a marking for the number one pin position. Install your Ribbon cable with the striped side towards the number one pin on both boards being connected.
Offline Chaz
« Reply #3 on: July 12, 2017, 04:21:06 PM »
Thanks. That helped.
Chaz
Offline deplanche
« Reply #4 on: July 12, 2017, 06:50:36 PM »
For future reference, the manual for is located here:
https://docs.google.com/document/d/1ewq6EqbTNqTQpeRP5CDWjen3088Gi9BQrQfEUoeJipA/edit?usp=sharing
See section 3.2.3 for how the ribbon cable is connected.
