Author Topic: F4V3 W Differential Expansion Boards  (Read 2021 times)
Offline toml8345
« on: August 28, 2017, 02:48:50 PM »
What is the maximum number of pixels that can be controlled per output with a F4V3 w/ 2 Differential Expansion Boards?  I am sure the information is somewhere on this forum, but I want to be sure I have my plan correct.  Also could we get the Specification Sheet updated with the new controllers and their capabilities?
  • Kudos: 74
Re: F4V3 W Differential Expansion Boards
« Reply #1 on: August 28, 2017, 04:48:06 PM »
Each of the 12 ports can output 1028 pixels.
Offline Sawdust
  • Kudos: 6
« Reply #2 on: August 28, 2017, 05:27:43 PM »
Yeah, that was hard for me to believe, but I trust you....and it does. Wow!
Offline deplanche
« Reply #3 on: August 28, 2017, 08:20:48 PM »
Isn't it 1024 per port?
Yes. Sorry my bad 1024
« Last Edit: August 28, 2017, 10:02:56 PM by David Pitts »
Offline uncledan
« Reply #4 on: September 10, 2017, 12:46:42 AM »
A little clarification on this if you could please David?  I take this as 1024 pixels on all 12 outputs? Pixelcontroller.com says 340 with expansion in 12 string mode.
Offline jeff
  • Howdy!
« Reply #5 on: September 10, 2017, 08:18:23 AM »
Expansion boards share ports with the main board. The number of pixels each board supports is configurable via the web interface. So port 1 on the main board shares a bucket of 1,024 pixels with port 1 on each expansion board.
Offline Sawdust
  • Kudos: 6
« Reply #6 on: September 10, 2017, 01:41:38 PM »
I do not believe that is the same for the F4V3 with Differential.  I have mine configured for 12 outputs, each with 1024 pixels.  12k total pixels, 36k channels
Offline jeff
  • Howdy!
« Reply #7 on: September 10, 2017, 02:09:18 PM »
Curious. What does the slider in the web interface show? Does the F4V3 support more than 1,024 per output?
Offline Sawdust
  • Kudos: 6
« Reply #8 on: September 10, 2017, 02:56:41 PM »
No slider on F4V3 - consider the F16 has 16 ports with 1024 pixels per port. total =16k  The F4V3 has the same 16k, but only 12 ports max to put them out, therefore 12k
Offline jeff
  • Howdy!
« Reply #9 on: September 10, 2017, 02:58:52 PM »
Thanks!
Offline uncledan
« Reply #10 on: September 10, 2017, 03:09:29 PM »
Thanks Sawdust, that's how I had mine configured too.  Didn't think this was possible... Guess it is!
Offline Sawdust
  • Kudos: 6
« Reply #11 on: September 10, 2017, 03:30:23 PM »
This F4v3 is such a remarkable controller, I bought one even when I have no need for one......but next yoar I may have 10-12k more pixels to install.
Offline fpga_brad
« Reply #12 on: December 24, 2017, 03:38:26 PM »
Mine says the limit is 120 pixels per port when in 12 port mode. I am running F4V3 V2.00. is there an update or did I mess something up somewhere?
« Reply #13 on: December 24, 2017, 04:41:16 PM »
From the F4v3 product page:
"1024 pixels per string in 4 string mode or 340 pixels per string with additional expansion board operating in 12 string mode."
(EDIT: Dave says 1024 on all 12 and has updated the product page.)
From the F4v2 product page:
"680 pixels per string in 4 string mode or 340 pixels per string with additional expansion board operating in 12 string mode."
« Last Edit: December 25, 2017, 09:02:39 AM by CaptainMurdoch »
  • Kudos: 74
« Reply #14 on: December 25, 2017, 06:32:17 AM »
I corrected webpage. The max pixels per sting is 1024 for all 12 possible strings.
