Author Topic: FPP E131 Config - Multiple Controllers same channels  (Read 192 times)
Offline twooly
  • Kudos: 13
« on: September 08, 2017, 01:35:00 PM »
Question regarding the e131 config within FPP and multiple controllers having some of the same channels.
I've got my FPP going to a network switch which has both a Etherdongle (channels 1-16384 first 4 universes of pixelnet) and a F16v2 (mostly channels above 16384).  My etherdongle goes into a falcon hub which feeds my house with those channels.  F16v2 does most of the above 16384 minus I want to run a couple props that are in the second pixelnet universe (4097 - 8192).
On the FPP e131 screen can I just leave the channels 4097-8192 on multicast and both the etherdongle and the f16v2 will respond and do the work to the assigned channels on each within that range?
Offline twooly
  • Kudos: 13
Re: FPP E131 Config - Multiple Controllers same channels
« Reply #1 on: September 09, 2017, 09:43:59 AM »
To answer my own question after some testing yes both controllers can have the channel range I just have to make sure that channel range is set for multicast vs just unicast to the controller.
