Author Topic: FPP to LAN via switch problems  (Read 359 times)
Offline Bob in WV
« on: February 22, 2014, 10:08:00 AM »
I have my show computer and FPP connected to a switch which is connected to my router.
The computer can connect to the internet so I know the connection is good.
The FPP start pages comes up, but none of the tabs work.
FPP status and FPP time are blank.
If I connect the FPP directly to the router I can access and control the FPP from another computer which is connected to the LAN.
Shouldn't FPP work through a switch?
Bob
Offline Bob in WV
Re: FPP to LAN via switch problems
« Reply #1 on: February 22, 2014, 11:04:47 AM »
SOLVED!!
Thanks to this board I found a reference to this type of problem in another post.  JAVA script was being blocked.
Bob
Online CaptainMurdoch
  • Kudos: 173
« Reply #2 on: February 22, 2014, 11:58:47 AM »
I made a note to take a look at this.  We should be able to put in a warning that will alert the user if they have JavaScript disabled.
