Author Topic: differential receiver board f4v2 vs. f4v3  (Read 729 times)
Offline Aaron Maue
  • Kudos: 9
« on: October 19, 2017, 09:48:32 AM »
I think I've seen a post somewhere saying something about one of the expansion boards working differently between the v2 (red) boards and the v3 (white) boards.  Even something about needing to remove one of the pins on one of the boards.
I've also seen some photos with the differential expansion boards connected to F4V2 and F4V3 hardware.  So, maybe I dreamed all this, as I can't seem to find definitive information, but thought I'd ask...
I will have a mix of F4V2 and F4V3 hardware in my setup.  I have also ordered a few of the differential expansion boards and receiver boards that are on their way to me.  Is there anything peculiar that I need to do in order to use the expansion boards with either the F4V2 or the F4V3?
Offline deplanche
Re: differential receiver board f4v2 vs. f4v3
« Reply #1 on: October 19, 2017, 10:36:05 AM »
If you are only using F4s (either v2 or v3), then everything is the same for the expansions and you can intermix without any problems.  It is only with F16s that some things aren't compatible.
