Author Topic: F16V2R - Lights Stay On  (Read 371 times)
Offline EButler
« on: November 13, 2017, 01:06:16 PM »
I have gotten out my last F16V2R that I had as a spare and using it to do some prop testing, etc.  When I go into the UI and update string port info and hit enter or press save, whatever light strings I have attached will flash and then random pixels will stay lit.  The only thing I have found to do is go into test mode, run a quick test, and then place make in normal mode and then the lights will go off completely.  Updated latest firmware
I am used to seeing the lights flash when updating the controller but none of my other V2R's will cause the pixels to stay on.  Any suggestions I should try next to troubleshoot?
Offline David Pitts
  • Kudos: 69
Re: F16V2R - Lights Stay On
« Reply #1 on: November 13, 2017, 08:10:17 PM »
Not sure. Set the controller to correct settings and then run test. It should be good from then on. I will have new firmware coming out soon.
Offline Shawn42
« Reply #2 on: November 14, 2017, 10:34:42 AM »
Dave, I have this happening on a brand new V3 that is straight out of the box. Only thing I changed was the ip. Still update the firmware?
Offline maguilar
« Reply #3 on: November 23, 2017, 11:46:26 PM »
What is the voltage going to the board? I noticed on mine (12v) when I turned the voltage up to anything above 13 some pixels would stay on.
Offline David Pitts
  • Kudos: 69
« Reply #4 on: November 24, 2017, 01:29:40 AM »
This will be fixed in the new release coming.
