Author Topic: FPD LAG?  (Read 1148 times)
Offline Frankr
    • Rocklin Lights
FPD LAG?
« on: December 06, 2017, 09:53:04 AM »
So I noticed last night while watching my show that the part of my show running off the FPD is lagging behind by a couple of frames. My setup is as follows:
fpp (master) pi3 w audio hat -> E1.31 out to 2 f16v2s. One f16v2 outputting 4 universes of pixelnet ~32k channels total
fpp(slave) BBB -> p10 matrix
fpp(slave) pi2 FPD -> outputs ~ 2 pixelnet universes
All connected to a wired ethernet switch
all the other channels seem to be in sync except the 2 universes coming out of the FPD. wondering if this is an issue with the FPD or possibly the lower power pi? I have several other pi3s I could deploy. or even attempt to deploy a pi3 to send e1.31 to the pi2 in in bridge mode.
Just looking for thoughts on the most likely approach to resolve the issue...
Last year I was not using the pixelnet output from my f16v2 so the lag was not as noticeable since most elements were on the same lag.
Thanks in  advance!
Frank
  • Kudos: 103
Re: FPD LAG?
« Reply #1 on: December 06, 2017, 10:21:12 AM »
Frank, my FPD is on a RasPi3 set as a Remote so no audio (and the Pi3 is noticeably faster than the Pi2)
It has 1 Pixelnet out (1200 pixels on an F16v1)
It has 2 DMX universes out (about 90 channels)
I'm driving 29 universes of E1.31 output to three IP addresses
So it's pretty busy. All that said, I'm not noticing any lag. Perhaps I don't program tightly enough to notice?
Offline Frankr
    • Rocklin Lights
Re: FPD LAG?
« Reply #2 on: December 06, 2017, 11:03:49 PM »
Switching to bridged mode with a separate pi doing the playback looks like it helped so likely a USB read issue.
