Not a Pi newby - but having issues with Alpha 2.0
Author Topic: Not a Pi newby - but having issues with Alpha 2.0  (Read 699 times)
Offline mschell
« on: March 25, 2014, 09:00:35 AM »
I'm not a newbie to the Pi - have done some projects with it for awhile.
I had a v1.x version of FPP running quite some time ago and just getting back to it.
I formated a 16GB card with the SD formatter, and loaded NOBS on it from the sourceforge site.
It goes thru the installation process fine with FPP Alpha-2.  After rebooting, I get the initial scrolling text screen and the FalconChristmas splash screen.   After that I just get a blank black screen.  Video is active, so it's not the monitor turning off.  Unit is connected to the network via wired connection, can access the internet, and gets a valid DHCP address.  I can ping it, but can't browse to it.   Rebooting doesn't help, even if I wait till all activity seems to be over.  I haven't tried ssh yet, but can if necessary.
I've had both a 4 GB and 8 GB USB key plugged in as well as a keyboard/mouse, just to see if that mattered.
This same Pi runs Debian Wheezy just fine on another SD card.
Thots?
Mark
Offline gdyrdave
Re: Not a Pi newby - but having issues with Alpha 2.0
« Reply #1 on: March 25, 2014, 09:59:38 AM »
Hit the space bar when you see the Falcon splash screen.
  • Kudos: 89
« Reply #2 on: March 25, 2014, 10:10:43 AM »
Mark
Having a USB Flash Drive plugged in is required. You mention having a keyboard/mouse also, so are you using a USB Hub?
I run my FPP without video/mouse/keyboard, using the web interface or SSH for everthing. The only time I ever had a problem was when I used a USB Flash Drive that had been used for normal PC storage and was not freshly formatted as FAT32.
Offline gdyrdave
« Reply #3 on: March 25, 2014, 11:02:20 AM »
I had the USB stick in but I still had to hit the space bar On the Falcon splash screen. I used an HDMI to VGA converter on the monitor. USB keyboard also. I don't think you can get the web pages for setup. Just a linux logon. That's just the way it worked for me.
  • Kudos: 50
« Reply #4 on: March 25, 2014, 02:16:01 PM »
As I recall it takes a second boot to complete the initial setup.
« Reply #5 on: March 25, 2014, 02:46:31 PM »
And you need to reboot again after the initial boot to get the latest code.
Also off the top of my head I can't remember, but I think that we don't start Apache the first time since the log directory doesn't exist yet.
So, for first-time v0.2.0 booters, "reboot". :)
I think we have worked around these issues already but the fixes aren't in the copy of our code that is in the v0.2.0 image.  We hope to release a new image in the next 4-6 weeks so that should end the double-boot for new users.
Offline mschell
« Reply #6 on: March 25, 2014, 03:50:46 PM »
OK, so I hit space bar, and got back to seeing the boot up info.
Am definitely getting a DHCP address.
Since there's no wireless card, or LCD or hwclock, these errors are expected.
I thot Apache wasn't coming up, did report an issue with finding it's FQDN, but when I browsed to the FPP from my desktop, it now seems to work.
Looks like both the local and remote Git versions match, so it's updated
Thanks for the help.
