Author Topic: .20 Help  (Read 926 times)
Offline twooly
.20 Help
« on: March 26, 2014, 02:00:25 PM »
First time trying to get it setup and not sure what I'm doing wrong.  I've now tried 3 times with the same results.  Pi is on the network/has an ip.  I can ping the ip but I can't get the web pages to show and I also can't ssh into it.  Won't take the username/password - pi/rasberry, but ssh does respond just can't login.
I use sdformatter doing a full format(overwrite) with format size adjustment on.  Copy the files extracted from the zip to the sd card.  Format the usb drive using fat 32 named MEDIA.  Put it all in the pi and let it sit ~20 mins or so.  I see at the beginning the activity light going nuts and then the usb drive being used also.  I have rebooted a couple times after the initial 20 mins but no luck.
Any tips.  Only things in the pi are the sd card/usb drive/ethernet cable/power cable.
Offline twooly
Re: .20 Help
« Reply #1 on: March 26, 2014, 02:22:44 PM »
Hmm seems to be related to the SD card.  Tried another one and it works now.  Odd since I was using the SD card for RasPlex.
Offline twooly
Re: .20 Help
« Reply #2 on: March 26, 2014, 02:25:21 PM »
Still can't ssh with pi/rasberry.  I wanted to setup my wifi adapter so the pi will only talk to my etherdongle.
Re: .20 Help
« Reply #3 on: March 26, 2014, 03:10:02 PM »
raspberry?  (did you forget the 'p' when logging in or just when typing it above?)  :)
Offline MyKroFt
  • Kudos: 57
Re: .20 Help
« Reply #4 on: March 26, 2014, 03:18:28 PM »
Plugging in some speaker or headphone while bootup will get you some audio info.  Remember after a initial load on the sd card, you will need to reboot twice if i remember.
Myk
Offline twooly
Re: .20 Help
« Reply #5 on: March 26, 2014, 04:11:02 PM »
Doh I feel stupid.  Thank you
Re: .20 Help
« Reply #6 on: March 26, 2014, 04:12:58 PM »
Been there, and done that.  That's why I just went ahead and put my ssh key on my Pi. :)
Offline twooly
Re: .20 Help
« Reply #7 on: March 26, 2014, 04:14:14 PM »
Doing that right now.  Who needs passwords :)
Offline arw01
Re: .20 Help
« Reply #8 on: March 26, 2014, 07:52:55 PM »
I'm sorry I noticed that  a few hours ago, but when you posted the 2nd time, I figured you just did a typo on the post..
Alan
Offline drlucas
Re: .20 Help
« Reply #9 on: March 27, 2014, 03:52:07 AM »
ditto on what Alan said....good catch Captain!
Ryan
Offline twooly
Re: .20 Help
« Reply #10 on: March 27, 2014, 04:26:30 AM »
No worries, just need to slow down I guess :)
