Author Topic: Operating systems  (Read 935 times)
Offline Santacarl
Operating systems
« on: April 02, 2014, 07:10:39 PM »
Hello All....
I'm looking to purchase a RPP.... I've noticed on a couple of the sites the following statement in the descriptions of the product......"SD Card loaded with the your choice of 6 different Raspberry Pi optimized operating systems."
My choice?  I'm assuming this is referring to NOOBs?  Being new to this product how do I know what my "choice" should be?
Thanks....
SC
  • Kudos: 86
Re: Operating systems
« Reply #1 on: April 02, 2014, 07:15:24 PM »
The places selling Raspberry PIs are not including the FalconPiPlayer OS as one of the 6. (though I'm sure it is based on one of them)
If you have 7 SD cards, you could have all of them available with just a Shutdown/Card Change/Reboot.
The FPP version is downloadable from this Forum and keeps itself updated from GitHub.
Offline MrChristmas2000
  • Kudos: 4
« Reply #2 on: April 02, 2014, 07:34:37 PM »
If you are not a unix/linux programmer it shouldn't matter what comes with it.
I'm assuming that you want to use it to run a light show and if that's true then JonB256 has your answer.
Online David Pitts
  • Kudos: 68
« Reply #3 on: April 02, 2014, 07:44:40 PM »
Correct. You dont need any of them. Most just buy the Raspberry Pi without a car and buy the SD card at Walmart.
Offline Santacarl
« Reply #4 on: April 02, 2014, 08:04:43 PM »
Thanks guys....
I had watched a tutorial on line and it was saying to keep the original NOOBs loaded card and purchase a new one and put my FPP software on it.....
Not knowing anything about the RPP I'm feeling my way along and the idea of 2 SD's had me a bit confused.  I suppose if I want to use the RPP in a different way then I would need to load the Linux or whatever.....
Is that what Jon was explaining when he referred to "Shutdown/Card Change/Reboot"
Online David Pitts
  • Kudos: 68
« Reply #5 on: April 02, 2014, 08:21:08 PM »
Yep. You can buy the cards anywhere though. All the images to run other distributions are free to download on the internet. All you need is a sd card writer. For FPP just buy the PI and a SD card somewhere also a 5V power supply and USB drive.
Offline MyKroFt
  • Kudos: 54
« Reply #6 on: April 02, 2014, 08:43:25 PM »
Al tho not required, I recommend a 2A USB charger/adapter....
Myk
Offline Santacarl
« Reply #7 on: April 02, 2014, 10:07:09 PM »
Thanks for the feedback......
Offline Santacarl
« Reply #8 on: April 03, 2014, 06:33:43 PM »
Myk
Does anyone have a recommendation for a good 2A.....maybe a retailer for it?
How about starter kits.....is 1 better than another?
Offline MyKroFt
  • Kudos: 54
« Reply #9 on: April 03, 2014, 07:09:14 PM »
I just got a generic 2A one off amazon....
Myk
