Author Topic: Replacement plugs...David please help  (Read 878 times)
Offline Todd
  • Kudos: 3
« on: February 05, 2018, 06:08:54 PM »
I can find the info for the replacement F16v3 plugs, I've been through here a couple times to see if I can find them for the Differential Receiver and I can't. I don't know if I'm missing it or what. I know they are smaller than the F16v3. Could you PLEASE give me the info to get a replacement plug. I lost one of mine. Also if I could get the replacement plug info for the F8 distro would be great also since I wouldn't mind having some spares.
Todd L.
Kimberly, WI
Offline Emuney18
  • Kudos: 4
Re: Replacement plugs...David please help
« Reply #1 on: February 05, 2018, 06:16:22 PM »
Differential receiver plugs are the same as the main F16 board
Offline Todd
  • Kudos: 3
« Reply #2 on: February 05, 2018, 06:24:12 PM »
I thought they were smaller. If that's the case I know what I need then.
Offline Emuney18
  • Kudos: 4
« Reply #3 on: February 05, 2018, 06:32:54 PM »
All of Davids plugs are the same except for the distribution boards and picap.  He did that to make life easier for everyone.
Offline MrTeaIOT
« Reply #4 on: February 05, 2018, 09:16:36 PM »
What plug are you talking about?  Picture please for newbie with F16v3 board..
Offline Emuney18
  • Kudos: 4
« Reply #5 on: February 06, 2018, 05:21:21 AM »
The green 4 pin connectors.  You can buy them here.
https://m.ebay.com/itm/20-pcs-4pin-way-Pitch-3-5mm-Screw-Terminal-Block-Connector-Green-Pluggable-Type-/230778118917?_mwBanner=1
Offline vipersinu2
« Reply #6 on: February 06, 2018, 06:58:51 AM »
Google this
phoenix connector 4 pin
Offline Todd
  • Kudos: 3
« Reply #7 on: February 06, 2018, 01:51:42 PM »
That's the one I had for the F16v3. I'm going to check tonight when I get home to make sure they are the same on the receiver board. Are these the F8 distro board? 2pin/way Pitch 3.5mm Screw Terminal Block Connector Green Pluggable Type
Offline Todd
  • Kudos: 3
« Reply #8 on: February 08, 2018, 04:19:42 PM »
I finally had a chance to check...The differential receiver board plugs ARE smaller than the F16v3 plugs.
Offline Emuney18
  • Kudos: 4
« Reply #9 on: February 08, 2018, 05:38:28 PM »
That has to be a mistake. I have 4 F16 and a bunch of receivers and have never separated the plugs. When you buy them they come in a ziplock and I have just dumped them all together and they worked fine.
Offline Todd
  • Kudos: 3
« Reply #10 on: February 09, 2018, 04:36:19 AM »
I have the white board receivers, not the red. Does that make a difference on the size of the plugs?
Offline sgryz
« Reply #11 on: February 09, 2018, 09:01:33 AM »
Todd
I have the white board also the plugs are the same size for the Falcon F16v3 and the receiver board.
  • Kudos: 178
« Reply #12 on: February 09, 2018, 09:11:36 AM »
I believe that David has used the same connectors on the F16v2 (blue & red), F16v3, and both red and white differential receiver boards.  I checked last night and the connectors from my F16v2 blue fit into the white differential receiver board socket correctly.
Offline Todd
  • Kudos: 3
« Reply #13 on: February 10, 2018, 03:27:04 PM »
Thanks all for the input. I have to admit...It was a user error. I had the extra F16V3 plugs in a drawer, not realizing I had an extra plug for my test board, which is a Holiday Coro Hinks Pix16, mixed in and not realizing Holiday Coro uses a differnt size plug. The Holiday Coro uses a slightly larger plug than the Falcons. I case anyone cares it looks like Falcon uses 3.5mm plugs and Holiday Coro uses 3.81mm plugs.
