Author Topic: Alpha 315 v2.x-master-574-g73f4a39a - - Elapsed or remaining time not working  (Read 769 times)
Offline brichi
Dan this is in line fixing the issue I had on the other thread too right being you mentioned "syncing issues"?
Yes.   The change is mostly the equivalent of setting the ForceSDL setting that you did.    Just kind of reverse.   The default is now SDL and there is a check box on the FPP settings page to enable the legacy outputs (only on Pi, BBB doesn't have the legacy programs installed).   Hopefully nobody needs that setting.
sounds good, thank you
Offline Sawdust
  • Kudos: 6
Giving a Big thumbs up for Ver v2.x-master-581-gcfe97eba  Elapsed or remaining time now working  :)
+1
