Author Topic: 2018/05/01 FPP new features - DDP out and Output Processors  (Read 601 times)
  • Kudos: 15
Re: 2018/05/01 FPP new features - DDP out and Output Processors
« Reply #15 on: May 14, 2018, 01:26:52 PM »
Been fiddling with my Pi running FPP 2.x, and to confirm it is currently on v2.x-master-581-gcfe97eba. I tried to perform a manual update on the device a few times, through the FPP About page, but kept encountering a fatal error:
Just FYI, I just tried it on a Pi 3B+ and went from 581 to 582 with no errors.
FPP Version:v2.x-master-582-g6ef7b300
FPP OS Build:v2.0alpha
OS Version:Raspbian GNU/Linux 9 (stretch)
Kernel Version:4.14.26-v7+
What is your Kernel Version?   Possibly you started with an older v2.x image build or possibly using different Pi hardware?
Edit:
Also worked on a BBB with no errors
OS Version:Debian GNU/Linux 9 (stretch)
Kernel Version:4.14.13-ti-r25
  • Kudos: 27
« Reply #16 on: May 14, 2018, 01:32:45 PM »
You're the second person that has mentioned that issue.   It looks like a config update didn't work at one point.   From the command line, can you do:
cat /etc/fpp/config_version
and let me know what it says?   Then do 'echo 29 | sudo tee /etc/fpp/config_version' and then redo the manual update and see if that helps.    In the update to config_version 32, it should have install the required dependencies.   For some reason, it looks like it didn't on yours, but I have no idea why that would happen.
Offline TastyHamSandwich
  • Big ideas, small hands
    • Jolt Lighting
« Reply #17 on: May 14, 2018, 01:38:41 PM »
Version Info
I believe it is the same version I started with in 2.x. I downloaded the latest image from the site, the one labelled FPP-v2.0-Alpha-Pi-20180315.zip.
I'm using a regular Pi 3, as well. Is 582 the latest version? I am still having problems with making FPPD start, whichever version this is.
UPDATE:
32
I'm trying the manual update now, just did the second command... Stand by.
    • Jolt Lighting
« Reply #18 on: May 14, 2018, 01:54:39 PM »
The manual update still failed. At the end, I saw the same failure as before. Attached is a pic of the start, as well as the .txt of the full log.
  • Kudos: 27
« Reply #19 on: May 14, 2018, 02:02:36 PM »
Looks like something has corrupted the apt-get/dpkg database.   Can you run the command mentioned in the update log ( sudo dpkg --configure -a ) , reset to config version 29 again, and redo the manual update?
    • Jolt Lighting
« Reply #20 on: May 14, 2018, 02:17:06 PM »
That seemed to bear some fruit there, Dan. It's in the process of updating right now, but it still seems like it has gotten past the hurdles already. Thanks!
    • Jolt Lighting
« Reply #21 on: May 14, 2018, 02:19:43 PM »
Okay, yes, the update was successful. It still shows its running 582, so I assume that is the latest version. The upshot, though: FPPD is working, and it is playing sequences without any apparent issue, now. Thanks again, O Linux Master! :)
  • Kudos: 15
« Reply #22 on: May 14, 2018, 02:53:16 PM »
Dan is da Man!  8)
