ÔĽŅ Raspberry PI3b+
Author Topic: Raspberry PI3b+  (Read 543 times)
Offline lightbalance
Raspberry PI3b+
« on: May 13, 2018, 08:18:52 AM »
Has anyone installed FPP on the new Pi3b+?  If so I need guidance the v1.8 wonít load.  I thought I read at one point that there is a beta version image that works for the 3b+ but I canít seem to locate it.  Any help is appreciated!
Offline Sawdust
  • Kudos: 6
Re: Raspberry PI3b+
« Reply #1 on: May 13, 2018, 08:55:43 AM »
Go to below link for beta - now Alpha, but skim the thread for updates and changes.  If it wonít run 1.8/1.9 or 1.10, then you should run Alpha V2.0 - remember it is in test so all features may not be working, and report those you find not working properly.
Hint: start with the Alpha 315 image.
http://falconchristmas.com/forum/index.php/topic,8795.msg81858.html#msg81858
  • Kudos: 50
Re: Raspberry PI3b+
« Reply #2 on: May 13, 2018, 02:25:27 PM »
The alpha image works fine on a 3B+  and seems very stable to me.
  • Kudos: 89
Re: Raspberry PI3b+
« Reply #3 on: May 13, 2018, 02:30:30 PM »
v2.x seems very stable on my Pi 3b+ and is noticeably faster to respond to the browser interface. (using it as a Remote to drive a ColorLight matrix board and 9 P10 panels) - no audio
Re: Raspberry PI3b+
« Reply #4 on: May 15, 2018, 10:58:39 AM »
Thanks Guys,  Iíll check it out when I get home tonight
Offline brichi
Re: Raspberry PI3b+
« Reply #5 on: May 15, 2018, 11:38:53 AM »
Will the pi3B+ handle my show? I have FSEQ files 1-2GB in size, im worried it may lag when loading or catching up being they're big sizes.
  • Kudos: 89
Re: Raspberry PI3b+
« Reply #6 on: May 15, 2018, 11:54:00 AM »
All my FSEQ files last year were 1.1gb to 750mb. No lag on a pi3B and the + is faster.
Just be sure the SD card is high quality and high speed. That is the weak point.
Offline brichi
Re: Raspberry PI3b+
« Reply #7 on: May 15, 2018, 11:59:03 AM »
I've been using the Samsung ones below, that should be good right?https://www.amazon.com/gp/product/B00WR4IJBE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1and you house all the media files like music, pics, video and so on files on the SD card or USB?
Offline pixelpuppy
  • Kudos: 20
Re: Raspberry PI3b+
« Reply #8 on: May 15, 2018, 11:59:54 AM »
^^^^^ THIS ^^^^^  And same goes for USB stick if you're using one.
Offline brichi
Re: Raspberry PI3b+
« Reply #9 on: May 15, 2018, 12:08:52 PM »
I have these usb's for my existing Pi's that seem good - https://www.amazon.com/gp/product/B013CCTJKE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
and these SD cards that are part of a Pi amazon kit - https://www.amazon.com/gp/product/B00WR4IJBE/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Re: Raspberry PI3b+
« Reply #10 on: May 16, 2018, 11:10:21 AM »
I downloaded the alpha image and loaded it on my 3B+.  It looked promising until it asked for a FPP login and password.  Now I seem stuck again?????
Offline pixelpuppy
  • Kudos: 20
Re: Raspberry PI3b+
« Reply #11 on: May 16, 2018, 11:21:50 AM »
  It looked promising until it asked for a FPP login and password.  Now I seem stuck again? ??? ?
Username: fpp
Password: falcon
That has always been there for command line.  But when you get to that point, its much easier to just use a web browser and connect to the FPP web interface (http://fpp.local) there is no login for that
  • Kudos: 89
Re: Raspberry PI3b+
« Reply #12 on: May 16, 2018, 11:24:26 AM »
If you are looking at a Monitor and have a keyboard, you will see a request for login.
The ID is  fpp
The password is falcon
BUT - unless you plan on doing "stuff" via the command line, it is unnecessary to ever login at that point.
All the real work is now done via the Web Interface of FPP. You get to it using the TCP/IP address assigned during bootup.
If you had a CAT5 cable attached during bootup, look up the screen a ways and you'll see it.
Just enter that address in a web browser on the same network (your Mac or PC or even smartphone)
If you don't have a CAT5 cable attached for network access, your RasPi is not really connected to anything (yet).
All further configuration will be done through the web browser, including config of a wireless connection.
Offline Sawdust
  • Kudos: 6
Re: Raspberry PI3b+
« Reply #13 on: May 16, 2018, 03:02:59 PM »
To further JonB256 comments........if you are seeing login, then a few lines up you will see my IP.  Type that IP Address into your browser command line to access FPP.  Then do a manual update.
Re: Raspberry PI3b+
« Reply #14 on: May 23, 2018, 12:41:52 PM »
Thanks again guys.  Iím a newbie to FPP Iíve been running my show for bout 8 years now using Xlights and a PC.  Finally decided to make the big jump to the Raspberry.
