Author Topic: V-FMT212R plugins testing with v2.x-master-581-gcfe97eba  (Read 132 times)
Offline JerryPlak
I have up loaded two logs   FPP_Logs_20180513.1618 this is for the Pi3+ and the FPP_Logs_20180513.1619 for the Pi3.
As you can see in the attached photo the plug-in is detecting the transmitter, but the transmitter is not transmitting a signal or audio on transmitter power light is flashing slowly.
Though at this point, I am not able to test for the "robot audio" issue..
JerryPlak
« Last Edit: May 14, 2018, 07:24:29 AM by JerryPlak »
Jerry Plak
