v2.x - Remote-Start playlist stops remote FPPD
Author Topic: v2.x - Remote-Start playlist stops remote FPPD  (Read 179 times)
Offline brichi
« on: May 13, 2018, 08:49:16 PM »
I downloaded and edited the remote start playlist script but when I run it it stops FPPD from running, If I send a script to run a remote script then it works fine but I cant use the script to run a remote playlist
Both Pi's are running the latest update as of 5/13/18   v
ersion:
v2.x-master-581-gcfe97eba (master branch
the ip of the master is 192.168.219.205
the ip of the remote is 192.168.219.206
the remote if switched to master can manually play the FSEQ in a playlist so I know thats good but when I put it in remote and trigger the playlist via the script below, it stops FPPD on .206
#!/bin/sh
# Remote-StartPlaylist.sh - Start a playlist on a remote  #
#                           system                        #
# The Playlist will play once and then stop.              #
# Edit this line to hold the playlist name in quotes
PLAYLISTNAME="tune"
# Fill in the IP of the FPP instance where you want to start the playlist
REMOTEIP="192.168.219.206"
/usr/bin/curl "http://${REMOTEIP}/fppxml.php?command=startPlaylist&playList=${PLAYLISTNAME}"
« Last Edit: May 14, 2018, 07:50:10 AM by brichi »
Offline JerryPlak
Re: v2.x - Remote-Start playlist stops remote FPPD
« Reply #1 on: May 14, 2018, 07:22:38 AM »
the ip of the master is 192.168.219.206
the ip of the remote should be 192.168.219.207
can't use the same ip on a network as one of the device will shut down there network port
Jerry Plak
Offline brichi
« Reply #2 on: May 14, 2018, 07:49:53 AM »
that was a typo, master is 205, sorry, I edited the first post
Offline JerryPlak
« Reply #3 on: May 14, 2018, 07:56:04 AM »
Offline Sawdust
  • Kudos: 6
« Reply #4 on: May 14, 2018, 10:04:06 AM »
I believe FPP is designed to Play the Playlist on the master and signal the remote the individual sequence to play.  The remote does not play a playlist.
Offline brichi
« Reply #5 on: May 14, 2018, 10:07:57 AM »
ah ok so me setting it up to trigger an effect (ESEQ file) via a script is the way to go
