Author Topic: v2.x-master-582-g6ef7b300  (Read 175 times)
Offline jbskelton
« on: May 14, 2018, 05:43:36 PM »
I am trying to setup the RPIWS281X on a Pi3b with a attached Pi-Cap.When I enable output & save I get a "Error restarting FPPD"If I disable the output & save FPPD starts as expected.Any Ideas?
Jbskelton
South Bend, In
  • Kudos: 86
Re: v2.x-master-582-g6ef7b300
« Reply #1 on: May 14, 2018, 06:19:37 PM »
When you enable a Pi-Cap, several things happen. First, it needs to disable the internal Sound system because the GPIO outputs are needed to drive pixels. That requires a Reboot, so it isn't surprising that FPPD doesn't restart properly if you haven't done a full reboot.
If you have rebooted (one or more times) and it still won't start, the Log files for FPPD should tell you what the conflict is. Logs are on the File Manager page in their own tab.
Offline jbskelton
« Reply #2 on: May 15, 2018, 12:33:51 PM »
I decided to revert back to fpp version 1.10 where the pi-cap runs as expected. I could not get the pi-cap to run on any of the v2.0 updates. fppd would not run with outputs enabled.
Thanks for the reply
  • Kudos: 86
« Reply #3 on: May 15, 2018, 06:09:47 PM »
I put a Falcon PiCap on a RasPi3B running v2.0-582.  Like you, when I configured and enabled the output, FPPD stopped. :(
Tried Standalone, Master, Bridge and Remote - no difference
In the fpp_init.log file, I get these entries:
Code: [Select]
pinMode: You have not called one of the wiringPiSetup
  functions, so I'm aborting your program before it crashes anyway.
FPP - Checking for Falcon hardware on SPI port
uncheck and save and FPPD restarts immediately.
  • Kudos: 27
« Reply #4 on: May 15, 2018, 07:27:17 PM »
Fixed
  • Kudos: 86
« Reply #5 on: May 16, 2018, 07:00:36 AM »
Fixed
Yes, it is!  FPPD is running now.
