FPPD 1.10 Stops
Author Topic: FPPD 1.10 Stops  (Read 123 times)
Offline jholmes
FPPD 1.10 Stops
« on: May 16, 2018, 08:38:49 AM »
Hi Friends,
I am having an issue where FPPD stops or stalls randomly.
The unit is running 1.10 and is not connected to the internet.
Here are my logs (which were set to Debug). Any ideas?
Code: [Select]
2017-09-17 08:17:08 (9250) channeloutput/channeloutputthread.c:174:Output Thread: Loop: 25000us, Send: 685us, Read: 46us, Sleep: 24267us, FrameNum: 5337
2017-09-17 08:17:09 (9250) channeloutput/channeloutputthread.c:174:Output Thread: Loop: 25000us, Send: 681us, Read: 43us, Sleep: 24275us, FrameNum: 5377
2017-09-17 08:17:10 (9250) Sequence.cpp:518:CloseSequenceFile() intermission.fseq
2017-09-17 08:17:10 (3429) Playlist.cpp:87:currentPlaylistEntry = 7 Last=0 maxEntryIndex=7 repeat=1
2017-09-17 08:17:10 (3429) Playlist.cpp:511:playListCount=7 CurrentPlaylistEntry = 0
2017-09-17 08:17:10 (3429) mediadetails.c:66:ParseMedia()
2017-09-17 08:17:10 (3429) events.c:337:TriggerEventByID(01_06)
2017-09-17 08:17:10 (3429) events.c:217:Event Loaded:
2017-09-17 08:17:10 (3429) events.c:219:Event Name  : play orbs and spheres
2017-09-17 08:17:10 (3429) events.c:223:Event ID    : 1/6
2017-09-17 08:17:10 (3429) events.c:226:Event Script: Remote-StartRepeatingPlaylist.sh
2017-09-17 08:17:10 (9268) controlrecv.c:111:ShutdownControlSocket()
2017-09-17 08:17:10 (9250) channeloutput/channeloutputthread.c:197:RunChannelOutputThread() completed
2017-09-17 08:17:10 (3429) Playlist.cpp:87:currentPlaylistEntry = 1 Last=0 maxEntryIndex=7 repeat=1
2017-09-17 08:17:10 (3429) Playlist.cpp:511:playListCount=7 CurrentPlaylistEntry = 1
2017-09-17 08:17:10 (3429) events.c:337:TriggerEventByID(01_01)
2017-09-17 08:17:10 (3429) events.c:219:Event Name  : play pixel wall
2017-09-17 08:17:10 (3429) events.c:223:Event ID    : 1/1
2017-09-17 08:17:10 (3429) events.c:230:Event Effect: pixel_wall
2017-09-17 08:17:10 (3429) events.c:231:Event St.Ch.: 0
2017-09-17 08:17:10 (3429) effects.c:149:Starting effect pixel_wall at channel 0
2017-09-17 08:19:25 (9277) Sequence.cpp:497:SendBlankingData()
2017-09-17 08:19:25 (3429) Playlist.cpp:87:currentPlaylistEntry = 4 Last=0 maxEntryIndex=7 repeat=1
2017-09-17 08:19:25 (3429) Playlist.cpp:511:playListCount=7 CurrentPlaylistEntry = 4
2017-09-17 08:19:25 (3429) mediadetails.c:66:ParseMedia()
2017-09-17 08:19:25 (3429) events.c:337:TriggerEventByID(01_05)
2017-09-17 01:49:33 (3264) settings.c:970:Volume change: 85
2017-09-17 01:49:33 (3264) log.c:218:=========================================
2017-09-17 01:49:33 (3264) log.c:219:FPP 1.10-20-g331eb1e
2017-09-17 01:49:33 (3264) log.c:220:Branch: v1.10
2017-09-17 01:49:33 (3264) log.c:221:=========================================
2017-09-17 01:49:33 (3270) gpio.c:66:SetupGPIOInput()
2017-09-17 01:49:33 (3270) gpio.c:105:0 GPIO Input(s) enabled
Offline jholmes
Re: FPPD 1.10 Stops
« Reply #1 on: May 16, 2018, 12:47:13 PM »
Update! I caught the "stop" in the act and discovered while FPPD is not listed as stopped, the playlist is skipping the FSEQ and instead looping the triggers over and over. See log below and let me know your thoughts?
Code: [Select]
2017-09-17 04:19:59 (3195) Scheduler.cpp:459:NowSecs = 15599, CurrEndSecs = 86399 (70800 seconds away)
2017-09-17 04:20:19 (5976) effects.c:427:Effect hv_rgb finished
2017-09-17 04:20:19 (5976) effects.c:427:Effect lv_rgb_beautiful finished
2017-09-17 04:20:19 (5976) effects.c:427:Effect rgb_tunnel_beautiful finished
2017-09-17 04:20:20 (5976) effects.c:427:Effect tunnel_beautiful finished
2017-09-17 04:20:20 (5976) effects.c:427:Effect dmx_shelf finished
2017-09-17 04:20:20 (3195) effects.c:149:Starting effect hv_rgb at channel 0
2017-09-17 04:20:20 (3195) effects.c:287:Effect hv_rgb step size 1344, model size: 1344
2017-09-17 04:20:20 (3195) effects.c:149:Starting effect lv_rgb_beautiful at channel 0
2017-09-17 04:20:20 (3195) effects.c:287:Effect lv_rgb_beautiful step size 108, model size: 108
2017-09-17 04:20:21 (3195) effects.c:149:Starting effect rgb_tunnel_beautiful at channel 0
2017-09-17 04:20:21 (3195) effects.c:287:Effect rgb_tunnel_beautiful step size 1936, model size: 1936
2017-09-17 04:20:21 (3195) effects.c:149:Starting effect tunnel_beautiful at channel 0
2017-09-17 04:20:21 (3195) effects.c:287:Effect tunnel_beautiful step size 396, model size: 396
2017-09-17 04:20:21 (3195) effects.c:149:Starting effect dmx_shelf at channel 0
2017-09-17 04:20:21 (3195) effects.c:287:Effect dmx_shelf step size 52, model size: 52
2017-09-17 04:22:36 (6395) effects.c:427:Effect hv_rgb finished
2017-09-17 04:22:36 (6395) effects.c:427:Effect lv_rgb_beautiful finished
2017-09-17 04:22:36 (6395) effects.c:427:Effect rgb_tunnel_beautiful finished
2017-09-17 04:22:36 (6395) effects.c:427:Effect tunnel_beautiful finished
2017-09-17 04:22:36 (6395) effects.c:427:Effect dmx_shelf finished
2017-09-17 04:22:36 (3195) effects.c:149:Starting effect hv_rgb at channel 0
2017-09-17 04:22:36 (3195) effects.c:287:Effect hv_rgb step size 1344, model size: 1344
2017-09-17 04:22:37 (3195) effects.c:149:Starting effect lv_rgb_beautiful at channel 0
2017-09-17 04:22:37 (3195) effects.c:287:Effect lv_rgb_beautiful step size 108, model size: 108
2017-09-17 04:22:37 (3195) effects.c:149:Starting effect rgb_tunnel_beautiful at channel 0
2017-09-17 04:22:37 (3195) effects.c:287:Effect rgb_tunnel_beautiful step size 1936, model size: 1936
2017-09-17 04:22:37 (3195) effects.c:149:Starting effect tunnel_beautiful at channel 0
2017-09-17 04:22:37 (3195) effects.c:287:Effect tunnel_beautiful step size 396, model size: 396
2017-09-17 04:22:37 (3195) effects.c:149:Starting effect dmx_shelf at channel 0
2017-09-17 04:22:37 (3195) effects.c:287:Effect dmx_shelf step size 52, model size: 52
2017-09-17 04:24:52 (6395) effects.c:427:Effect hv_rgb finished
2017-09-17 04:24:52 (6395) effects.c:427:Effect lv_rgb_beautiful finished
2017-09-17 04:24:52 (6395) effects.c:427:Effect rgb_tunnel_beautiful finished
2017-09-17 04:24:52 (6395) effects.c:427:Effect tunnel_beautiful finished
2017-09-17 04:24:53 (6395) effects.c:427:Effect dmx_shelf finished
2017-09-17 04:24:53 (3195) effects.c:149:Starting effect hv_rgb at channel 0
2017-09-17 04:24:53 (3195) effects.c:287:Effect hv_rgb step size 1344, model size: 1344
2017-09-17 04:24:53 (3195) effects.c:149:Starting effect lv_rgb_beautiful at channel 0
2017-09-17 04:24:53 (3195) effects.c:287:Effect lv_rgb_beautiful step size 108, model size: 108
2017-09-17 04:24:53 (3195) effects.c:149:Starting effect rgb_tunnel_beautiful at channel 0
2017-09-17 04:24:53 (3195) effects.c:287:Effect rgb_tunnel_beautiful step size 1936, model size: 1936
2017-09-17 04:24:53 (3195) effects.c:149:Starting effect tunnel_beautiful at channel 0
2017-09-17 04:24:53 (3195) effects.c:287:Effect tunnel_beautiful step size 396, model size: 396
2017-09-17 04:24:54 (3195) effects.c:149:Starting effect dmx_shelf at channel 0
2017-09-17 04:24:54 (3195) effects.c:287:Effect dmx_shelf step size 52, model size: 52
2017-09-17 04:24:59 (3195) Scheduler.cpp:459:NowSecs = 15899, CurrEndSecs = 86399 (70500 seconds away)
2017-09-17 04:27:08 (6395) effects.c:427:Effect hv_rgb finished
2017-09-17 04:27:08 (6395) effects.c:427:Effect lv_rgb_beautiful finished
2017-09-17 04:27:08 (6395) effects.c:427:Effect rgb_tunnel_beautiful finished
2017-09-17 04:27:09 (6395) effects.c:427:Effect tunnel_beautiful finished
2017-09-17 04:27:09 (6395) effects.c:427:Effect dmx_shelf finished
2017-09-17 04:27:09 (3195) effects.c:149:Starting effect hv_rgb at channel 0
2017-09-17 04:27:09 (3195) effects.c:287:Effect hv_rgb step size 1344, model size: 1344
2017-09-17 04:27:09 (3195) effects.c:149:Starting effect lv_rgb_beautiful at channel 0
2017-09-17 04:27:09 (3195) effects.c:287:Effect lv_rgb_beautiful step size 108, model size: 108
2017-09-17 04:27:09 (3195) effects.c:149:Starting effect rgb_tunnel_beautiful at channel 0
2017-09-17 04:27:09 (3195) effects.c:287:Effect rgb_tunnel_beautiful step size 1936, model size: 1936
2017-09-17 04:27:10 (3195) effects.c:149:Starting effect tunnel_beautiful at channel 0
2017-09-17 04:27:10 (3195) effects.c:287:Effect tunnel_beautiful step size 396, model size: 396
2017-09-17 04:27:10 (3195) effects.c:149:Starting effect dmx_shelf at channel 0
2017-09-17 04:27:10 (3195) effects.c:287:Effect dmx_shelf step size 52, model size: 52
2017-09-17 04:29:24 (6445) effects.c:427:Effect hv_rgb finished
2017-09-17 04:29:24 (6445) effects.c:427:Effect lv_rgb_beautiful finished
2017-09-17 04:29:25 (6445) effects.c:427:Effect rgb_tunnel_beautiful finished
2017-09-17 04:29:25 (6445) effects.c:427:Effect tunnel_beautiful finished
2017-09-17 04:29:25 (6445) effects.c:427:Effect dmx_shelf finished
2017-09-17 04:29:25 (3195) effects.c:149:Starting effect hv_rgb at channel 0
2017-09-17 04:29:25 (3195) effects.c:287:Effect hv_rgb step size 1344, model size: 1344
2017-09-17 04:29:25 (3195) effects.c:149:Starting effect lv_rgb_beautiful at channel 0
2017-09-17 04:29:25 (3195) effects.c:287:Effect lv_rgb_beautiful step size 108, model size: 108
2017-09-17 04:29:26 (3195) effects.c:149:Starting effect rgb_tunnel_beautiful at channel 0
2017-09-17 04:29:26 (3195) effects.c:287:Effect rgb_tunnel_beautiful step size 1936, model size: 1936
2017-09-17 04:29:26 (3195) effects.c:149:Starting effect tunnel_beautiful at channel 0
2017-09-17 04:29:26 (3195) effects.c:287:Effect tunnel_beautiful step size 396, model size: 396
2017-09-17 04:29:26 (3195) effects.c:149:Starting effect dmx_shelf at channel 0
2017-09-17 04:29:26 (3195) effects.c:287:Effect dmx_shelf step size 52, model size: 52
2017-09-17 04:29:59 (3195) Scheduler.cpp:459:NowSecs = 16199, CurrEndSecs = 86399 (70200 seconds away)
2017-09-17 04:31:41 (6445) effects.c:427:Effect hv_rgb finished
2017-09-17 04:31:41 (6445) effects.c:427:Effect lv_rgb_beautiful finished
2017-09-17 04:31:41 (6445) effects.c:427:Effect rgb_tunnel_beautiful finished
2017-09-17 04:31:41 (6445) effects.c:427:Effect tunnel_beautiful finished
2017-09-17 04:31:41 (6445) effects.c:427:Effect dmx_shelf finished
2017-09-17 04:31:42 (3195) effects.c:149:Starting effect hv_rgb at channel 0
2017-09-17 04:31:42 (3195) effects.c:287:Effect hv_rgb step size 1344, model size: 1344
2017-09-17 04:31:42 (3195) effects.c:149:Starting effect lv_rgb_beautiful at channel 0
2017-09-17 04:31:42 (3195) effects.c:287:Effect lv_rgb_beautiful step size 108, model size: 108
2017-09-17 04:31:42 (3195) effects.c:149:Starting effect rgb_tunnel_beautiful at channel 0
2017-09-17 04:31:42 (3195) effects.c:287:Effect rgb_tunnel_beautiful step size 1936, model size: 1936
2017-09-17 04:31:42 (3195) effects.c:149:Starting effect tunnel_beautiful at channel 0
2017-09-17 04:31:42 (3195) effects.c:287:Effect tunnel_beautiful step size 396, model size: 396
2017-09-17 04:31:42 (3195) effects.c:149:Starting effect dmx_shelf at channel 0
2017-09-17 04:31:42 (3195) effects.c:287:Effect dmx_shelf step size 52, model size: 52
2017-09-17 04:33:57 (6445) effects.c:427:Effect hv_rgb finished
2017-09-17 04:33:57 (6445) effects.c:427:Effect lv_rgb_beautiful finished
2017-09-17 04:33:57 (6445) effects.c:427:Effect rgb_tunnel_beautiful finished
2017-09-17 04:33:57 (6445) effects.c:427:Effect tunnel_beautiful finished
2017-09-17 04:33:58 (6445) effects.c:427:Effect dmx_shelf finished
2017-09-17 04:33:58 (3195) effects.c:149:Starting effect hv_rgb at channel 0
2017-09-17 04:33:58 (3195) effects.c:287:Effect hv_rgb step size 1344, model size: 1344
2017-09-17 04:33:58 (3195) effects.c:149:Starting effect lv_rgb_beautiful at channel 0
