Author Topic: v2.x-master-590-gddac8c49 - Files wont upload  (Read 90 times)
Offline Kasper
« on: May 17, 2018, 06:44:09 AM »
Hey guys - trying to set up my new Pi3B+'s
Installed Alpha image, and works fine, network and storage has been set up...
when trying to upload files... FSEQ files.... it runs, goes green and says close... but when i press sequence files.... the folder is empty ??
Any suggestions ?
Offline JerryPlak
Re: v2.x-master-590-gddac8c49 - Files wont upload
« Reply #1 on: May 17, 2018, 06:51:44 AM »
Can you post a screenshot of your fpp setting page
Jerry Plak
Offline Kasper
« Reply #2 on: May 17, 2018, 07:00:50 AM »
Sure - here it is
https://i.imgur.com/KFMwr4C.png
arh - is it the USB drive name ? it has to be called Media right ?
Offline brichi
« Reply #3 on: May 17, 2018, 07:14:53 AM »
what if you try using a FTP program or file browser and type in \\192.168.0.32 in your case. then navigate to sequences and copy the file over. I have had better luck not using the FPP uploaded and using stuff like FileZilla or Mac SMB in finder to upload
also if you make the USB FAT32 and "dont format" when you select it its the Pi device you can simply plug the usb drive into your computer and just copy the sequences right into the sequence folder
Offline Kasper
« Reply #4 on: May 17, 2018, 07:17:04 AM »
I got it !
Im from Denmark - so using letters from our alphabet, makes it reject it i guess ?
renamed all the files to english - and boom then it worked :)
Offline JerryPlak
« Reply #5 on: May 17, 2018, 07:26:37 AM »
I got it !
Great News  now have fun playing  8) with FPP
