Author Topic: 4 pin pigtales used for 3 pin??  (Read 244 times)
Offline Jojoed
« on: June 20, 2018, 10:42:48 AM »
Has anyone tried this? I have several 4 pin pigtales left over from a lot sale I bought and need a few more 3 pin just curious if this would work
Offline Sawdust
Re: 4 pin pigtales used for 3 pin??
« Reply #1 on: June 20, 2018, 02:00:53 PM »
Would be no problem, just cut the 4th lead stripped portion and do not wire them.  You will need to pick a color and be uniform throughout...now and in the future.    Just to be clear - 4 pin do not connect to 3 pin.
Offline Jojoed
« Reply #2 on: June 21, 2018, 11:37:04 AM »
Thats what I was thinking also but I was just trying to save a few dollars ya know
And yeah I understand that assuming I connect everything correctly
Just wanted to make sure there wouldnt be any conflicts with fourth pin being there
Thanks for ur help
Also on a completely other topic
I want to build a 5x5 matrix is there any good threads that have required material
Info  ect...
Offline j_czerwin
« Reply #3 on: June 22, 2018, 02:09:38 PM »
Totally works and I also do it with 3 wire pigtails when I only need 2 wires for power injection.
JUST MAKE SURE TO LABEL THEM CLEARLY as mixing them will cause you problems big time.
I use shrink wrap colors over unique connectors but you could use paint or tags.
And either way, probably still meter them when hooking things up.
Good luck!
