ÔĽŅ Sync all remotes
Author Topic: Sync all remotes  (Read 494 times)
Offline MATTS
Re: Sync all remotes
« Reply #15 on: August 03, 2018, 10:06:40 AM »
here's some parts of the log I found. Not sure what you need to see but if you tell me what to look for I'll try to find it.
2016-11-03 12:55:19 (4547) MultiSync.cpp:1319:ProcessSyncPacket()
2016-11-03 12:55:19 (5267) channeloutput/channeloutputthread.c:188:Output Thread: Loop: 35000us, Send: 41672us, Read: 31180us, Sleep: 0us, FrameNum:
350
2016-11-03 12:55:19 (4547) channeloutput/channeloutputthread.c:415:LightDelay: 35000, newLightDelay: 35000
2016-11-03 12:55:20 (4547) MultiSync.cpp:1319:ProcessSyncPacket()
2016-11-03 12:55:20 (4547) channeloutput/channeloutputthread.c:415:LightDelay: 35000, newLightDelay: 35000
2016-11-03 12:55:20 (5267) channeloutput/channeloutputthread.c:188:Output Thread: Loop: 35000us, Send: 14010us, Read: 37357us, Sleep: 0us, FrameNum:
367
2016-11-03 12:55:20 (4547) command.c:611:s 8,0,0,Thunderstruck2.fseq,,18,274
2016-11-03 12:55:21 (4547) MultiSync.cpp:1319:ProcessSyncPacket()
2016-11-03 12:55:21 (4547) channeloutput/channeloutputthread.c:415:LightDelay: 35000, newLightDelay: 35000
2016-11-03 12:55:21 (5267) channeloutput/channeloutputthread.c:188:Output Thread: Loop: 35000us, Send: 41417us, Read: 29838us, Sleep: 0us, FrameNum:
384
2016-11-03 12:55:22 (4547) MultiSync.cpp:1319:ProcessSyncPacket()
2016-11-03 12:55:22 (4547) channeloutput/channeloutputthread.c:415:LightDelay: 35000, newLightDelay: 35000
2016-11-03 12:55:22 (5267) channeloutput/channeloutputthread.c:188:Output Thread: Loop: 35000us, Send: 14853us, Read: 28510us, Sleep: 0us, FrameNum:
402
2016-11-03 12:55:22 (4547) command.c:611:s 8,0,0,Thunderstruck2.fseq,,20,272
Offline MATTS
« Reply #16 on: August 03, 2018, 10:29:24 AM »
I've tried less intense sequences and the BBB still lags behind. I've also tried changing my panel config to half the panels and it still lags behind.
  • Kudos: 35
« Reply #17 on: August 05, 2018, 04:39:22 PM »
What kind of SD card are you using?  With: Read of almost 30ms, that is SLOOOOOW.  Certainly won't work with 25ms sequences.
Also, are you using btrfs or ext4?
  • Kudos: 35
« Reply #18 on: August 05, 2018, 05:10:11 PM »
Actually, can you do an update and re-try.   The "Read" time also included any processing time for overlays and video matrices and such.  I've broken that into a different value so I'd like to see which is the slower part.
Offline MATTS
« Reply #19 on: August 05, 2018, 05:49:52 PM »
Dan,
I am using 32gig Samsung evo flash card. I used the BTFS when I mounted it. Iím pretty sure that all worked because my fseq files donít take much space so them should be pretty compressed.
Iíll try to do an update tonight. is there a new image or do I go to the developer page?
  • Kudos: 35
« Reply #20 on: August 05, 2018, 06:27:29 PM »
Developer page and update....
You MAY want to also try the ext4 image.   btrfs is nice as it compresses everything.  However, the compression also takes up CPU time which, for a matrix your size, might be needed for other things.
Offline brichi
« Reply #21 on: August 06, 2018, 03:35:32 PM »
I'm noticing this too the last few weeks of updates including the latest 644-g035a8e8d  that my Master Pi keeps jumping way ahead in time over the remotes, I have a 15 minute pre-show sequence with a 15 minute audio track, it all triggers fine and as it gets closer to 5:30 in the time keeps jumping up more and more over the remotes. You can see in the video how the Master is already 3-4 seconds ahead of the remotes and but the end its almost 2:30 seconds quicker ending the remotes way off including the image on the screens, The master is skipping ahead but the audio sounds fine. anything that seems to be under 5:30 minutes are fine, its just this long 15 minute sequence that goes off track
video explaining and showing it all - https://youtu.be/dIWO1GpaqpE
RunningMaster - Pi 3B+
Remotes are Pi 3 B's
I just tested something that works. The original 15 minute sequence was a musical one like I mentioned, I converted that In sequence settings to "animation" being in FPP the track is separate anyway. Not the sequence is animation in XLights with no audio track packaged into the fpp and now all the Pi's stay in sync so maybe this is an issue only when you have a 15minute audio track packaged into the sequence?
Offline MATTS
« Reply #22 on: August 12, 2018, 12:21:40 PM »
Dan,
It looks like the ext4 did the trick. Iíll do some more testing but at first glance everything looks great.
Thanks,
Matt
