Author Topic: Pinout for Minleon pixels waterproof connector  (Read 302 times)
Online JonB256
  • Kudos: 102
« on: July 24, 2018, 05:42:38 AM »
At Expo, I picked up some "4inch RGB Orbs" at the Reinders booth. They are Minleon products and came with a nice "Smart T" needed to string many of them along
BUT - two things are not apparent and not marked. Now, I could spend about $50 on a Minleon supplies page for a Power Injection setup.
when all I really need to know is:
1.  Which connector is "input"  (I found one reference that implied that the "female" end was output)
2.  On the "input"  which pins are +12vdc, Data and Ground
The chipset is TLS3001 (not a problem) but they have deliberately left everything unmarked.
« Last Edit: July 24, 2018, 06:44:32 AM by JonB256 »
Online JonB256
  • Kudos: 102
Re: Pinout for Minleon pixels waterproof connector
« Reply #1 on: July 27, 2018, 07:10:38 AM »
Duh - just needed a much brighter flashlight  8)
Inside the 3-wire connectors (male or female), molded into the plastic, it shows the pin layout.
thanks to Paul at Reinders (an Expo vendor!) for illuminating my path.
