Author Topic: V2.x suggested scripts  (Read 187 times)
Offline PeteyHall
« on: August 05, 2018, 06:23:13 PM »
Under 1.x, I executed a number of scripts to ensure FPP was constantly running and stable (e.g. fppdWatcherStart.sh, UserCallbackHook.sh, etc).
With v2.x should I install the same scripts or do the stability improvements built into v2 not make them worth it?  Are there any other ones those who've been beta testing would recommend?
  • Kudos: 103
Re: V2.x suggested scripts
« Reply #1 on: August 05, 2018, 07:53:29 PM »
I have a test Master/Remote setup running. All are v2.x and updated frequently. There is one Master (a BBB) with 5 Remotes (3 RasPi and 2 BBB). Also a RasPi3b+ in standalone but running the same sequences and schedule.
Several weeks back, when Dan found and fixed a DMA value problem that plagued my RasPi3B+, this setup has been super stable.
There is a "jquery" problem that just popped up from a change 10 days ago, but that should be fixed in a day or two.
if you won't be running an actual display until October, then I highly recommend installing the new images.
If you having something running right now and depend on it, I'll leave that call up to you.
« Last Edit: August 05, 2018, 08:08:10 PM by JonB256 »
Offline PeteyHall
« Reply #2 on: August 07, 2018, 07:04:11 PM »
Thanks for the feedback.
What about the read-only script to help minimize corruption when shutting down unexpectedly/not clean?  Is 2.x more tolerant than 1.x or should I run the script to make the drive read only?
