Falcon Hub Assembly Manual authored by RichM
Author Topic: Falcon Hub Assembly Manual authored by RichM  (Read 3654 times)
  • Kudos: 69
« on: May 23, 2014, 01:54:23 PM »
Falcon Hub Assembly Manual can be found here.
http://falconchristmas.com/forum/index.php?action=downloads;sa=view;down=34
Thanks Rich for the manual it looks great.
  • Kudos: 69
Re: Falcon Hub Assembly Manual authored by RichM
« Reply #1 on: May 23, 2014, 02:01:38 PM »
we need to get it in the wiki if someone wants to start a wiki page.
Offline RichM
« Reply #2 on: May 23, 2014, 06:29:33 PM »
David, will there be a firmware release soon?  Or did I just miss it somewhere already on here?
My board is ready, just need the pic file to start playing with it.
Rich
  • Kudos: 69
« Reply #3 on: May 23, 2014, 06:30:47 PM »
Rich
Other then the DMX output you can use it without firmware. But there will be firmware soon.
Offline RichM
« Reply #4 on: May 23, 2014, 06:35:29 PM »
Good to know.  I don't need the DMX right now, but I will be using the DMX out during the show.  :)
  • Kudos: 89
« Reply #5 on: September 05, 2014, 12:14:49 PM »
It is just Red XXXXXs in the manual and too small for me to read on the PIC.  8)
What is the PIC model number?
  • Kudos: 69
« Reply #6 on: September 05, 2014, 12:34:24 PM »
PIC32MX564F064H
  • Kudos: 89
« Reply #7 on: September 05, 2014, 01:05:07 PM »
Programmed the Hub with MPLAB IPE v2.15
Programming gave no errors and said "verified"
But when I Verify, it says "Fail"
Normal, or is there something I need to do in MPLAB IPE advanced settings?
I do get a blue LED flash when I program the Hub. That's got to be a good sign, right?
« Last Edit: September 05, 2014, 03:11:26 PM by JonB256 »
