Author Topic: ARCHES BLINKING  (Read 151 times)
Offline ROY G
ARCHES BLINKING
« on: September 12, 2018, 01:24:39 PM »
Good day, Guys. i'm having problems with my arches. i have a f16v3 with a differential receiver board hooked up. arches 1&2 and 5&6 are connected to output 1 &output 3 and work just find, but arches 3&4 and 7&8 blink  white an are connected to outputs 2&4 on the receiver board. i used the same cabling & aches to test each output. Anybody have an ideas where i shuld be looking ?
  • Kudos: 103
Re: ARCHES BLINKING
« Reply #1 on: September 12, 2018, 06:33:51 PM »
The blinking is when
a.  nothing is happening
b.  sequence is playing
c.  in F16 test mode
d.  Other____________
  • Kudos: 103
Re: ARCHES BLINKING
« Reply #2 on: September 12, 2018, 09:20:06 PM »
Or, you get Dave Pitts to help you find a bad cat5 cable
Offline ROY G
Re: ARCHES BLINKING
« Reply #3 on: September 15, 2018, 08:42:21 AM »
Thanks for he reply and yes David Pitts did indeed help me out. It was a bad ethernet cable between  expansion board and receiver. Thanks again to david .
